hey guys i have an 97 stagea and im wonderig what the norm is for idleing on the highway? at around 100 to 110ks mine sits on 3 grand.... just seems to high.... feels like the auto needs to drop back.
have had it to the auto shop and hooked it up to the scanners. everythings doing what it is supposed to. was told that it could be the tps switch that might need adjusting. adjusted it in increments to no success. weird thing is it has an open centre in it?? thought it would run an lsd???
any other ideas.???
also the 4wd doesent work. havent even looked into this problem yet. where do i start????
https://www.sau.com.au/forums/topic/168724-idle-at-100k/
do a search in the general automotive section, I remember seeing a DIY in there about reseting idle and it had something to do with an air bleed on the plennum.
Mine (was) at 2500 - 2600 at 100kph and I have 17" on 45 series and a stock as a rock auto.
https://www.sau.com.au/forums/topic/168724-idle-at-100k/#findComment-3117996
thats a real worry - has the attessa pump got any fluid in it?
It may just need bleeding, but I would have a close look at it if I were you. Running the pump and/or transfer case dry (if that is the problem) can get very expensive. Usually, the only way to get a stagea to run in RWD only is to drop the front driveshaft out - the old "just pull the 4WD fuse" doesn't really work and can actually cause damage if left like that.
https://www.sau.com.au/forums/topic/168724-idle-at-100k/#findComment-3118075
Mines auto and sits just on 2500. Worked out it does just on 40k/1000 when the converter is locked up. Am running 17"
225/50/17 Federal595'
Just a further on this.
I got wacked twice for "exceeding the speed limit" but concluded the checking methods were suss. No charges.
I run a general rule, 10, 20, 30, 40 kph/1000rpm in 1st, 2nd 3rd OD. Around the Mountain (town) I now popthe OD to OFF.
Keep to 2000 and no dramas. Thats what I do.
It is interesting to see that there is quite a difference between various owners. you would have to check on the final drive ratio
and the actual diameter of your wheels to see exactly where each vehiclewas at. And if auto that the converter actually does lock up.
My old RMR30 (used to) did 50k/1000, locked up. Couldn't get her started for her final triptoday. I think she knew.
She used to peak about 4250. But the RMR30 were a very slippery vehicle and had one of the lowest coefficients of drag
factors of most cars of its time. It is what made them fast, not quick, fast.
So there are a lot of factors that govern the revs/km. All aspects have to be taken into consideration.
Owning a NIssan is such fun. I have five. Well four after today.
https://www.sau.com.au/forums/topic/168724-idle-at-100k/#findComment-3119526
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
