i just checked all my levels on my hand controler. after getting the back out around a corner and hitting the rev limter in second my knock level read a max of 79.
my previous highest knock level was a 19 again when hitting the limter.
i had to double check what i was reading because it seemed a lot high
https://www.sau.com.au/forums/topic/168815-pfc-read-knock-level-of-79/
could be a dodgy batch of fuel? boost spiking? ambient temp when attempting the sideways action?
i didnt actually see a question in there but im assuming you wanna know why it was knocking so much? personally, i wouldnt be too worried about it as long as your not doing it 24/7, even then 79 isnt too high. from memory the PFC cuts in to warn you at about 60 which is well short of doing any damage
yeh sorry mate.. what i was asking is firstly could this be a correct reading and secondly how bad of a reading is this.. the engine light did come on how ever when it happened. injector duty was below 90% and a/f was 5110 but i do have a Z32 afm so i dont think thats the prob.
what is a reading to be worried about
engine light typically set at 60 knock and anything above that is a concern if it is only happening at the limiter easy fix dont hit the limiter
unless you see it all the time I wouldn't loose to much sleep if its pretty regular ask your tuner he might be able to put more fuel or less ignition at the limit point
might help?!?
Woulda thought 90% injector duty is pushing it too much too?
Edited by noone
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
