Hey,
Was gettin my link ecu tuned today on an R33 gtst series 2 and the tuner had issues of ithe car missing on all sorts of boost levels...
Its got the right plugs in it, fuel pressure is there, just wondering if anyone else had issues or if know whats causing it.
thanks!
https://www.sau.com.au/forums/topic/169081-gts-link-ecu/
the car has run 10 psi on stock computer and had no problems, this missing that the tuner had was sometimes at 4 psi sometimes at 10 (inconsistent), he thinks it may be the fact that R33's series 2 do not have an igniter on them compared to series 1.
https://www.sau.com.au/forums/topic/169081-gts-link-ecu/#findComment-3125468
plugs chosen by the tuner gapped to 0.6mm
Thats the problem right there.
If you have to gap the plugs any further than .8mm, its a dead give away you have a problem with the ignition :)
And that usually means (in order of occurence, first being most common)
* One or more coil packs is stuffed
* Wrong plugs are being used
* AFM might need a clean
* Faulty connectors/loom somewhere causing a weak spark to be produced
* CAS not working correctly.
https://www.sau.com.au/forums/topic/169081-gts-link-ecu/#findComment-3125480
Well if it doesnt use the AFM, just pretend that point isnt there and read to the next one.
Mute point.
Yes, the increase boost (as already stated) is causing the spark to blow out.
1psi can have that effect if your on the limit already. It could also be the coils have now deteriorated even more.
Surely your tuner knows all this? Or are they just guessing?
https://www.sau.com.au/forums/topic/169081-gts-link-ecu/#findComment-3125498
Mute point.
what 1 psi are you reffering to? this missing was inconsistent happened at 4 psi, 10 psi, sometimes the can ran smooth, the next run it would miss as soon as it hit boost.
Doubt the coil have deteriorated even more cause i ran 10psi for no more than 3 weeks with the stock ecu...
what do you think about the igniter difference between S1 and S2?
Edited by Mid_Nite_R33
https://www.sau.com.au/forums/topic/169081-gts-link-ecu/#findComment-3125507
Dude, ive given you the advice (as have others), if you wanna argue/doubt/whatever. So be it.
Go pay someone lots of money and dont bother with forum advice
not trying to argue anything dude, just trying to work out what the problem is given what people say on here and with what i know about my car.
https://www.sau.com.au/forums/topic/169081-gts-link-ecu/#findComment-3125531
He is right but there is some stuff missing from the story which is worth knowing. Link ECUs only have 4 coil drivers, so the way that it deals with your 6 coils (I had this issue too) is it fires 2 at a time - much like you do with wasted spark. One will be the one which is actually due for an ignition stroke, the other will be going into exhaust stroke. If your coils are getting "tired" then even if it was all working fine before putting the Link in, when they have to go double time due to the Links way of getting around of too few coil drivers they will show their weakness.
Only way around it is new coil packs or the more logical way which would be to convert to wasted spark, seeing as thats how the ECU is treating them anyway.
https://www.sau.com.au/forums/topic/169081-gts-link-ecu/#findComment-3129021
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
