CRD were going to charge me $250, and kept telling me my car would have to be retuned, even though it was tuned perfectly just needed to have the boost controller setup...
Went to C&V told them it was tuned, told them all my mods etc etc... they tuned it... (took about 30power runs, was playing up a bit)... gave me dyno print outs... told me to take it for a drive to make sure i was happy then come back and pay them $150...
done and done :kiss:
Sounds Good Thanx Champ :P
mr 1h82bu, I'm going to do you a favour. on the forum we expect a minimum level of coherent comunication. this is not a text message to your cuz. this is a question posted on a forum. spelling mistakes happen, poor grammar happens. lack of capitilization happens. BUT typing non-stop in this sms crap is going to mean you are in for a tough time on the forum, and eventually mods and admins will get sick of the conflict it (you) create and you'll get the boot. so please do us a favour and type in the best english you can muster. please.
would u care to share ur experience.. was it a bad tune ??? was it not wat u expected ? details plssss
After their 'tune' the car was pinging excessively during normal driving, which as you know can kill an engine - I took the car back to them two more times for no further improvement. (and no refund)
I live in the Blue Mountains so obviously this was a huge inconvenience.
I eventually took it to Ric Shaw who got running fine.
The last tune I had was Bel Garage (different car) and I was impressed with them. They do a road tune then finesse it on the dyno depending on what application you want it tuned for.
It is actually important that you decide what your application is and let the tunner know - if you get the car tuned for drags don't expect it to be happy in the traffic.
From the feedback on the forum over the past couple of years it seems CRD, the Hitman or Unigroup are the go.
i hpe i hve put ths in trms u kan undrstand
All these posts about tune...and you already wanna go there...GOOO..and good luck...:)
Muck F**k will be with you...
EUG.
Was asking for opinions . i dont think theres anything wrong with that....
By the way can you all read my english now.....
You do a wonderful job, i think i love you :)
yes... dear god thank you!
its nothing personal, i jst dun lyk hving a voce n mi hed sound lyk dis...
hope to see you out on a cruise sometime ;)
edit: and good luck with the tune! wish i was at that stage :)
C&V tuned my GTR and it went backwards . In my opinion steer clear .
If you dont mind me asking what was so bad about the tune ???
i am starting to think about getting the car tuned somewere else.. Bel Garage is like 5 Minutes away from my house all my friends have tuned there cars there too they havent had any problemss...
Cam wheels were all over the place as were the fuel maps std cam rb26 with hks 2530's at 1.2bar on unigroup dyno car made 260rwkw and best time out at WSID I think was a 12.3@112-114mph and air temp about 16deg. So yeh pretty much not performing as it should gave it to Ben at Bel back out at WSID with 28deg air temp the car went 11.9@117mph on the first pass and then a few months later 11.6@119mph with a slipping clutch air temp that night about 20deg .
Rolled the car back up on the unigroup dyno it put down 300rwkw so yeh bit of a difference . I don't know who does the tuning at Bel now but Ben isn't there anymore but he does still tune and uses a dyno log dyno in the Gong . I haven't much to do with these things anymore but I might still be able to chase his number up if you like? .
Thank you.. if i need any further help i will pm u.. Thanks Alot :P
i on the other hand have a very good experiences, with c&v.
other than the excessive waiting hours on end, even sometimes not being able to get my car tuned,
but in the end, over approx a 3 year period i never had to change spark plugs,
my car has never ever pingend,
i made more power on low boost than expected, also with lazy timing and no cam gear timing.
they did exactly what i wanted.
all in all i guess it comes to who u personally trust
Yeah i figured there would be alot of mixed opinions, but its good to know the good and the bad ..
cheers guys for the help
  • 2 months later...
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
