hey guys just swapped an r32 rb20det into my silvia (91) and I have the following mods:
blitz sus LM intake
HKS dump
high flow cat & 3" exhaust
stock turbo
cooler
boost
'puter
i'm running the non-turbo fuel pump just getting back and forth to work, not getting into it. do I NEED to upgrade fuel pump if its all stock? I was thinking a GTR fuel pump and am afraid of running rich and dealing with tuneing. better to run rich then lean i guess.
all input appreciated :) ..cheers
https://www.sau.com.au/forums/topic/169360-upgrade-fuel-pump/
I'd probably upgrade it just to be safe buddy, wouldn't want something to go wrong after all the money you have outlaid just for a $200-300 part.
maybe a gtr pump and a nismo fpr? anyone know proper fuel pressure psi? yes I wouldn't be happy if something happened to the rb... can't afford a skyline, but the rb20 is good 'nough for me....they sound sooo nice. :)
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
