Hey guys!
Currently setting up my new project.
Im on the hunt for 500kw on the rears.
Interested in knowing the following
- cams? 256?264?272?
- Turbo? 3540? T04z? Gt42?
- How Much boost?
- Injector Size? 750?850?1000cc?
Is there anyone on the forum that has 400/ 500 kw setup in their car.
Curious to know how much work is required plus the components needed.
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/
R32 GTR
Apexi PFC D-Jetro
Garrett t04Z turbo running 24psi
Apexi 53mm External Gate
Sard 700cc injectors
HKS Fuel Rail
HKS Fuel Reg
HKS Step II cams 272 272 10.2mm lift ,
HKS Valve Springs ,
HKS Valve Guides.
HKS adjustable cam wheels
Jun Oil Pump
Arias pistons with n1 rings
Pauter Conrods
608rwhp or 454 rwkw's at 24psi on Ultimate 98
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3133635
As per the graph, max power is 578 hp at the rear wheels. This is an improvement of 37 hp on the same dyno by fitting a 272IN cam (previous 264) and spending dyno time optimising cam timing.
Setup is:
N1 block
HKS 2.8L crank
Nismo bearings
Pauter rods
ATI crank damper
HKS nickel coated pistons
GT-RS low mounts at 25 psi
HKS bridged manifold
HKS hard piping induction kit
Apexi 136mm IC
Greddy plenum
HKS fuel rail (twin entry, single return)
HKS fuel regulator
HKS 680 injectors
Nismo intank fuel pump (direct power feed)
HKS step 2 cams (272IN, 272EX)
HKS guides, springs and retainers
HKS timing belt
HKS cam gears
HKS metal head gasket
Ported head
Trust oil pump
N1 water pump
HKS dumps, pipes and exhaust
PFC D-Jetro
Blitz dual solenoid BC
Splitfire coils
HKS Twin Power CDI
HKS twin plate clutch
GTS4 diff centres front and rear (shorter ratio than GT-R)
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3133643
just picked up my new GTR
1992 GTR
1000cc injectors
3X bosch fuel pumps
Standard plenum
re-ground standard cams
ARP rods
unknown pistons
T51R SPL BB turbo
AP racing Triple place clutch
Autronic computer X2
re built standard gearbox
AFR btween 12 and 13
last dyno:
631.3 ft/lb torque
578 kw at all 4
775.2 hp at all 4
that was running 2bar
dyno sheets to follow when i get scanner working
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3133647
Setup is:
N1 block
HKS 2.8L crank
Nismo bearings
Pauter rods
ATI crank damper
Apexi 136mm IC
Greddy plenum
HKS fuel regulator
HKS 680 injectors
HKS timing belt
HKS cam gears
Ported head
Trust oil pump
N1 water pump
PFC D-Jetro
Splitfire coils
HKS Twin Power CDI
I just made that same power with GT-RS turbo's on 21 psi with pump fuel and a light tune.
a few differences though Nissan crank, bigger cams, more headwork. but much the same. All big $$ brand name stuff, Jun Hypertune etc. It will see some more boost this week as well as some race fuel and increased timing figures.
but budget at least $25000-$30000
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3133679
1990 R32 GTR
Split fire coils
HKS 264/8.9 cams
OS Giken cam gears (not tuned)
Sard 850cc inj
Bosch 044 intank
stock internals/cooler etc
Jasma cat(less) back
HKS T45 S Spl turbine kit (cast manifold 50mm ext gate 4" dump, screamer)
RB20 afms
Apexi pods
Apexi Power FC
411.1 rwhp@ .7 bar
Rebuilt engine results soon..
Ceramic coated .5mm o/s CP forgies
Teflon coated skirts
Eagle Rods
King bearings
N1 pumps
HEad tickled
Port matched manifolds
Apexi 270/8.9 cams
Nismo head gasket 1.2mm
Blue printed/balanced crank (9000rpm)
Jun collar
Z32 afms
Ceramic coated exh manifolds/turbo/wastegate
Greddy Eo-1 ebc
Billet fuel rail
Sard fpr
Tomie sump baffle kit
Mines rocker cover baffle kit
Trust R intercooler
Apexi hard pipe kit
Aiming around 6-650 rwhp @1.5-1.8bar
Has already run 12.1@120mph before rebuild
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3133681
Once the new 1000cc injectors arrive
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3133748
ive got 2.7 jun stroker, 270 in/exh 10.8 cams hks t04z denso 1000cc injectors all the other bullshit along with it, hoping for around 450kw plus gas :)
after a year of building should be done next few weeks :D
Edited by 747.GTR
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3134119
Arrive at good reputation workshop with 1 x GTR R32, R33, R34 who cares.........
Open cheque book and say " how much for 500kw at the rear wheels?"
Expect to write a cheque for at least $30,000.00
Arrive 2 to 3 weeks later to pick up 500kw GTR
Drive off down the road smiling smuggly to yourself knowing that you will have one of the fastest cars to 50km/h on the planet. :thumbsup:
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3138544
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
