Always like watching this one, It's a 250cc Superkart doing Isle Of Man! If you've ever seen these bad boys out at Mallala they are as quick if not quicker than V8 Supercar!
http://www.youtube.com/watch?v=3Q1JCyVle1k
And this one is killa, Another 250cc Superkart doing Laguna Seca, everyone knows Laguna:
Point and shoot, thats what kartings all about, F#@k i love karting!!!!
Enjoy
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
