http://www.youtube.com/watch?v=T8Doy_7sOoM
hahaha, that is NUTS
http://youtube.com/watch?v=I-pkTmOpjtQ&feature=related
i'm not a huge fan of S15's, but using a jzx90 to kill it is a bit of a waste IMO
When i saw that the first time a while back, i actually cried because of how much i laughed. Love the commentators !
Edited by KISIN
:P:):wub: :wub: :wub: :wub: :wub: :wub:
wish i had 400K spare, cos i would have this beast in my dirveway
make sure you have your speakers up loud around the 1.12minute mark
Edited by Whiplash
Those of you old enough (like me) will enjoy this Peter Russell Clarke clip - it makes you proud to be an Aussie!!!
I guess some of you were born long after he stopped being famous and have never heard of him :huh: Enjoy anyhow!
http://au.youtube.com/watch?v=IFyVaLO5amQ
I guess some of you were born long after he stopped being famous and have never heard of him :/ Enjoy anyhow!
OMG peter russel clarke was on just after inspector gadget back in the day.. what a winning combo ! :huh:
Edited by bezender
I guess some of you were born long after he stopped being famous and have never heard of him :) Enjoy anyhow!
I actually remeber some of Clarkey's ads.......how sad is that!!
thats a pretty nice car jump but i dont think it beats this 1
http://www.youtube.com/watch?v=qDi0MZJZ-w0
and this 1 for sheer stupidity (lengthy intro u may want to skip)
i mean the dude barely makes it to the water asks after wards if he made the distance, umm not quite buddy. and what was the plan if he did land it when he was that messed up from landing in the water
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
