no offense cause that rx is quite a cool car, but tell me you blew it up and thats why you now have an RB.
and is ya name mark?
haha sorry mate im a rota head through and through, i only bought the stagea for the misses. otherwise i would have bought a rx8 or similar. i already have 3 other mazdas and now the NISSAN.
and yes its Mark. :)
p.s. it didnt blow up. lol.... its in a full makeover period. full tubs, 4link rear end. fully braced 9in. strange diff and centre. coil over rera end. 17x11's. full cage. 20bt. :)
^^very nice car but cant understand doing that for like 5minutes to the poor thing
have you ever heard the phrase.
'built to thrash' ???
thats exactly what my intentions were when i built the car. and dont intend of changing anything.. hehe
major redneck lol lol lol gota watch this 1 in adelaide to apparently, cam car sounds like its got exhaust and something wrong with the engine
adelaide street drifting illegal
http://www.youtube.com/watch?v=heOhgj3GGI8...feature=related
Edited by Inline 6
and yes its Mark. :blink:
it diddnt blow up :blush: you must no someone who can build decent rotors. you gave me n my mate a good show at that gazzas we got a bit of a soft spot for a good chooka. good luck with the build sounds awsome.
whats wrong with you bezender, yeah the dude likes rotors but we forgive him ;)
jus playing dude i considered 1 of my friends rx7 the best car i had been in for some time prior to my skyline ways :blush:
and wheres your vid to go with your post as i have now done :)
for the nba fans, my fav is the guy throwin the ball in the air thinking its over and the player catching it and knocking down the 3 to tie at the buzzer.
Edited by Inline 6
LOL @ that meth head.
what a complete wanker.
bet he has a real nice life
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
