Yeah exactly. Im trying to figure out what movie that is.
The producers etc would be locked up if that happened now.
theres a ZOO in nth Korea with lions and tigers in captivity together. They fight. Cant believe they get away with that these days
anybody fammilar with the maxboost?
http://www.youtube.com/watch?v=UwXhgV_xySQ
http://autocannon.com/autocannon2009v2/Max...r_Magazine.html
unfortunately they dont have the original comic strip up anymore but it was pretty funny. kid thinks his mum is getting him a vtec and go's home to find the pea green civic. full of lil jokes about v8bogans :blush:
good find Craig.........over 400hp, 10sec car, RB25 with stock cams & internals (apart from forged pistons)......that's all you need for up to 500hp in a 26 IMO.....stock rods are fine as long as you avoid the biggest killers for all RB's, detonation and oil & fuel surge.
I wouldnt believe a word that dick says, 10 sec my arse, gets my blood boiling seeing that cock head, if you only knew how much dodgey shit that guy did in his rain or terror. They didnt call his tuning "panic" tune for nothing!!!!
Haha, you know something we don't Adrian.
Yeah 10 sec sounds like he's mixing his abilities with his aspirations......or just playing with himself.
I still stand by my statement on internals and what kills an engine though, regardless of this twit.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
