Ford certainly did the falcon a big favour bringing out the turbo model.
caugh caugh 2 forced induction falcons at the top (gt 335)( f6310) how else would u want it :cheers: supercharged 5.0 all alloy beaudiful less than 3k in mods are netting close to 90rwkw gains and bulk torque and to think these will be worth sub 40k in a short few years 12 sec 1/4ers are nice STOCK
Edited by JETURBO
pinch.gif ill save it for another forum dont want to fill this place with holden /ford banter :whistling:
ok fark it ill do it
http://www.uniquecarsandparts.com.au/car_info_ford_falcon_gt.htm
and this was way back when
Hey can't argue with the old GT's - play that card and it's always going to be a winner in your Ford and Holden debates.
I was more so implying the 6T is an absolute winner for the falcon in a sense of that 20 odd year gap between the time of those said GTs models you hint about above, and early 2000's... The falcon wasn't exactly too much of an appealing model to performance enthusiasts (...V8 supercar fans aside!).
And I don't know much about the very latest models, but weren't the top of the line 6T's (f6/typhoon etc) quicker than the V8s?
Jet that was done on a Disney Dyno and for some reason (Fords moreso than Skylines) tend to read a shit load of power more on D & D's for some reason....Skylines also read a little more but not as much.
As for the Blown GT 335, when it goes down to $35K, I'm getting one!!
Correct.....and still are
i reckn i nearly got the d/d debate sorted pete yes there terriable with accurate numbers moreso with the ford , i reckn and this is just me, the older 2wd d/d's that have had some years of work blow out with big torque cars that come on earlie , but the 4wd d/d's seems to hold a decent life span acuracy wise ............................any mainlie seems to be a winner regardless of age. ive just been having a look at what alot of ppl are saying across many forums and it does seem to be a common theme n/a cars seem to have the least problems on any dyno. but ill do my head in trying to work it out :teehee: yeh the new gt has a fairly consistant 300rwkw stock on any dyno still great numbers and 114mph is the biscuit right there ......................."Dyno figures make for good conversation, mph at the strip proves it without reservation" ............:cheers:
yeh the b series turbo single handedly saved ford aust no doubt
i was being serious lol if the b series never came out i really doubt we would have a need for ford aust
skyline humm driven heaps every other mate has one but no never owned one looked very seriously at a R34 GTR b4 buying the f6 but just to small cabin wise and for some reason every GTR owner is broke haha, i can see something comming up soon hence the stalking on here just checking some bits out
Ahh nice! Well you obviously love power judging by your sigs; if you do end up landing one I doubt it would be tame machine...
OT wise, much respect for the 6T though. My brother in law had one, and that's the only car that scared the living shit out of me! Insane power
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
