^^ >_< shit imho
meh, your entitled to your opinion, but to me there probably a million times better than anything you listen too =\
was just sharing incase there was anyone else from SAU there, i know there are a few metal heads on here! lml
Ha lowest form of wit right there
You agree its my opinion and im entitled to it yet proceed to flame my music without even knowing what i listen too gg Luke
Some people like listening to people scream i dont, the drummer sounded very good just couldn't listen to the song for long as that grate's me
music is something people (me) are very pasionate about, so why wouldn't i defend my choice??
i could have said lots of nasty and things about what music i've seen you post if i wanted to be petty and arrogant, but i didn't and didn't as you say "flame your music", i didn't even call your music shit, i just said i liked that music more. i dont need to know what you like to say "that if you think that is shit, i like whatever you do more"... least thats how i look at it
i just felt that your original comment was uncalled for and inflamatory "if you cant say nothing nice, dont say anything at all??". I tryed my best to defend my position without enflaming the situation, clearly that didn't work
and yes, one of the best drummers i've ever heard! =)
edit: sorry, pm wasnt working for me for some reason =\
seems you can get in the guiness book of records for anything
If you have ever played that song on easy, youll know how hard it is. I reckon he has more talent/skill than plenty of other guiness record holders!
talent and skill have no right being in the same sentence as guitar hero
what he was playing (either pettrucci or malmstein) is almost >impossible< to play on a real guitar.... and anyone who can even do a poor cover generally gets credit, as those two guys are insane...
and luke, what about joey jordison from slipknot? one hell of a drummer right there
-D
for the basketballers
if you dont watch that much nba, gillbert arenas was recently charged for pulling out a gun on his teammate in an argument about gambling debts. he was still allowed to play untill the court case untill he got suspended when he kept making jokes pointing his hands as guns at team mates.
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
