  • Replies 74
Posted Images
  • 2 months later...
oh right, yeh the subject of topic notifications is back to default
also, the topic notications still have all the new lines doubled up. ie this:
NewKleer,
Madaz has just posted a reply to a topic that you have subscribed to titled "Pm Email Notification".
Hi Christian we've lost Topic notification in email's again hope this is an easy fix due to the last upgrade
PS: do you not leave trader comments?
rather than this
NewKleer,
this has been "broken" for quite a while though. nissansilvia forums have same problem
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
    • You can trust Rezz!
    • Just to get this straight if you turn the splined shaft to the outside, it turns freely but the chain does not move? What happens when you move the chain, does the splined shaft turn? Surely the shaft is snapped, or the chain is seized and it took the teeth off whatever great is behind the steel bracket
