  • Replies 44
Posted Images
Mate! What is your A/F ratio? I think you are running too rich or your tunner did not do a good job. I have the same set up but was running mega rich. Power was about the same as yours and my tunner took off 10 - 12% of the fuel through out the rev range and Whala.........power jumped to 176rwkw with only 10psi of boost on stock turbo.
https://www.sau.com.au/forums/topic/169854-dyno-run/#findComment-3138574
hi flow cat yes, knn filter, split fire coil packs,
man if i post up my dyno run video the thing was making flames at the back
the tuner said i need a fuel regulator as the fuel pump is putting in too much fuel
where on the dyno sheet does it tell ur afr rations... i'll zoom in on everytihng i can find n upload pics
Edited by Zas)-(
https://www.sau.com.au/forums/topic/169854-dyno-run/#findComment-3138579
Hey Dude
i think that is on the low side i got 158rkw absolutely stock, 170rkw with crap dump pipe and 8psi boost.If you dont have a dump pipe i think you might gain some more kws also a Hi-flow cat will help, cheers
https://www.sau.com.au/forums/topic/169854-dyno-run/#findComment-3138581
Zas,
Are you using stock fuel reg? If so, you do not need the walbro fuel pump for under 200rwkw. Put back your stock fuel pump with your stock fuel regulator and tune it. You will get the power everyone is getting for that setup. If you want to go more then 200rwkw, then get your turbo hiflow, walbro fuel pump with stock fuel reg and a proper tune, you will be able to get close to 230rwkw.
https://www.sau.com.au/forums/topic/169854-dyno-run/#findComment-3138600
yes i am using a stock fuel regulator
the tuner advised me to get a after market fuel regulator to make it better
though... 230 ? with just a turbo.. jumping anoth 77 kw man dats a big jump???
no i ahve a 3 inch dump, hi flow cat, 3.5 inch catback exhaust with a large blits front mount, electronic profec b, apexi neo, Knn air filter, SPlitfires, Walbro fuel pump
stock fuel regulator , stock turbo and a small green haired troll
Edited by Zas)-(
https://www.sau.com.au/forums/topic/169854-dyno-run/#findComment-3138603
yeah i was told that my fuel pump was maxed out too. car was runnning was rich like 9:1 ratio. ridiciulous. creatd leaned it up to a safe 12:1 and from 150ish rwk i made 182 just from the a/f. and 10 psi boost. i have a hiflow tho. who tuned your car?
Edited by R33GOD
https://www.sau.com.au/forums/topic/169854-dyno-run/#findComment-3138607
yeah his saying that theres too much fuel pressure and he cant tune it down?
need a fuel pressure regulator ....
thats onli 10 psi i got this score from boosting up .9 pounds
is motor racing....they did few drift cars in the hot fours....
https://www.sau.com.au/forums/topic/169854-dyno-run/#findComment-3138616
Zas,
Sorry, thats incorrect.
Its a very very wise idea to upgrade the fuel pump over stock.
Time and time again you see people here asking why they are leaning out, and each time its the stock fuel pump.
The tuner advised me to get a after market fuel regulator to make it better
Thats shocking advise from your tuner mate. Unless the factory fuel reg is stuffed, which going by the dyno graph its fine, then fair enough.
But the stock reg is perfect for the task.
A fuel reg will not "give" you power unless you have maxed out the stock injectors, which wont occur until around 230-240rwkw.
And you dont have that power, you need a bigger turbo for a start.
I also reckon the tune you have whilst conservative... its a little "too" conservative, ie. its way to rich, and this is evident by the car blowing flames.
You dont need 11:1 AFR's, its too rich. 11.5-12:1 is what your after and even thats not leaning on the car.
In all honesty, the tune is crap. The advice your being given, is also crap.
I would be looking for a refund and finding a new tuner.
cheers
Also .9 bar = too much boost on the stock turbo.
There is a risk you'll blow it.
https://www.sau.com.au/forums/topic/169854-dyno-run/#findComment-3138680
Im with nismoid. That tune is average. and the advise your being given is poor as well
Leave the pump in it, leave the stock fuel reg drop the boost slightly to prolong the turbo's life and have it tunned properly.
At that sort of mod level id be tunning it to roughly 12.2 :1 and it will make very decent power, I know you only have a neo so there is only basic tunning to do but honestly that AFR graph looks like something my apprentice could knock out.
https://www.sau.com.au/forums/topic/169854-dyno-run/#findComment-3138855
he couldnt get it any higher he sed?
with boosting at 0.9 pounds he was running it max to 153 .5
so nismoids adice being that i dont need a fuel regulator i need a new tuner lol
whata waste of 500 bucks and new platinum plugs ( to which he sed my coppers where shitted on ) fair nuff...
___
____ paulr33 : what do u mean get the neo tuned?
they installed the neo, they tuned it? unless u mean go sumewhere else?
https://www.sau.com.au/forums/topic/169854-dyno-run/#findComment-3139166
Cant get what any higher? the power?
Thats because they clearly don't know how to tune. 11:1 AFR's are silly and that's what's causing your poor power.
The car will also feel quite lazy as well. You'll be amazed what a good tune feels like
paulr33 means somewhere else, only because if the tuner calls that being "tuned"... then they have done an incredibly bad job, which isn't cool.
As it looks like they have not "tuned" it at all, well... i lie... It looks like the made changes to the tune, but all the wrong ones and nothing right :)
Also plati plugs are a waste of money.
dollar for dollar coppers are far better, also work just as well, if not better
https://www.sau.com.au/forums/topic/169854-dyno-run/#findComment-3139226
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
