Check for a vacume leak like a leaking manifold gasket or intercooler pipes and all the vacume hoses even a small leak can cause problems. The easy way to check for a leak is to have the engine idling and spray engine start over all the hoses inlet manifold and intercooler pipes if there is a leak the engine will rev up or splutter when the engine start gets sucked in.
  • Replies 46
yeah going to chech that today, i have some pluming end caps to allow for plumming up of the air compressor and looking for leaks that way.
also founf on the net that the plug near the washer bottle can couse problems, so i am going to clean it up and redo the connection to make sure it's AOK.
other then that i am out of idea.
I did a log of the car this morning and noticed that as soon as it does this and goes funny, the oxygen sensor drops to zero and then bounces back then back to zero,
dropping to zero means really lean, ie could be fuel cut. what do injector duty cycle say as same point?
post up your consult logs would help
just cause the ecu is remapped doesnt mean its necessarily remapped "properly". a few stray values and the car might be cutting all fuel for given points in the map. can the rom be downloaded with consult? if so maybe u could check that out with some rom editor software and see if anything looks dodgy whereever you're having problems
I have the .bin file for it i will PM you with it. It definatly has not got boost cut on the ECU. Like i said teh ECU ran fine for about 6 months, no issues it was briliant, and somethign has gone wrong since then to make it liek it is.
I will do another log of the car tomorrow morning and post it up for you all to see.
I have had a new CAS and AFm on, no differance, new TP and ACC valve, no change, have 6 new injectors to chuck in it and do a full blown leak test on the piping.
did u get any fault codes? under 3500 rpm sounds like possibly a knock sensor issue
and im not up to speed on rom stuff, but if there is a secondary knock map, then maybe its detecting a bit of knock, and then using that knock map (which could have the dodgy value in it) or simply the knock protection is what ur feeling (r&r)
not sure if the ecu listens to knock sensor at idle though, so you may have another issue there.
well got a new ecu and no go still the same issue. I did a full log this morning and am about to go over it and have a look.
I was thinking Knock sensors to, but accoriding to my SAFC II no matter which one i connect to, thy both show simmilar values. I have a set to put on, so that is next on the line.
This may fixnumber two, but still starts like a dog in the morning.
As for fault codes, sweet FA.
This sort of sounds like what my car is doing atm. It's standard apart from a 3 inch straight through exhaust and a pod filter. It keeps stopping. Like if you drive along it will stop and then jerk back into life again. It doesn't seem to be related to anything. The only thing maybe is that when it is warm cos i don't remember it doing it while its been cold. I'm thinking it could be something to do with the ingnition because if it was coilpacks it would just miss wouldn't it?
Good luck with your problem WogsRus, hopefully your solution will help me :P
Cheers
Stricko
EDIT: Oh BTW i'm trying to get hold of an ECU Diagnostic tool to see what i can find. Will post the results.
Edited by stricko
yeah well still searching. I did a pressure test on all IC piping and connection, 50psi and holding no issues there. Still to pressure test the planum.
Getting a new PCV valve for the rocker just in case.
I had two more ecus and it's not that. Nothing to do with mapping, as i had my mates PFC and it still does it with that, and his can has same mods and power.
I have replaced 90% electrical componenets and still nothing. Going to go over teh wiring loom as there has to be something worong with it. HAS too.
boooohhooooo,
pretty sure 0 = lean, which means u have a fuel problem (rather than ignition...if fuel was getting in but no ign, o2 sensor would be rich)
had ur injectors tested/replaced at all? ran any additives etc?
u really need to post logs though...eg is the fuel problem because the ECU is telling the injectors not to inject, or because the injectors arent injecting the fuel (even though the ecu is telling them to)? eg is there an input sensor (afm, engine temp, cas etc) that is messing up at that rpm due to vibration etc, and the ecu is responding accordingly? cant tell without the logs.
i have an a stock reg and a 1:1 rising rate on inline as a precortion. I have the log i posted it here.
http://www.skylinesaustralia.com/forums/in...howtopic=170677
So far i have showed it to a couple of people and taking their instructions on board.
Cheers
Stricko
check or replace the CAS with a known good one and see if problem goes away.
Edited by URAS
Cheers
Stricko
Right i've had the ECU diagnostic tool plugged into my car and went for a drive. The CAS reading went up to about 6000rpm even though the engine speed wasn't this and the when it jerked back into life the CAS reading came back to normal. Getting a new CAS ASAP to hopefully fix my problem. The ECU diagnostic tool also said there was a AFM problem. Could this just be because of the CAS being dodgy or could my AFM need replacing as well?
BTW car is a 1993 R32 Skyline GTS-T Type M with 86000kms, 3inch straight through exhaust and pod filter.
Cheers
Stricko
Edited by stricko
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
