  • Replies 40
the security cameras that are in the tunnel already catch speeders all dependsif the guys watching can be bothered making a call to cops about it but from the roumers i have heard i wont be speeding in the tunnel from now on after last weekends both ways shutdown of the polly pipe :)
But it sounds so cool when you speed in the tunnel... not that I ever have. The speed cameras at the entry/exit (going either way) do a good enough revenue raising job anyway, maybe they're going to up the ante since they have to pay even more for the overblown perth to mandurah railway line we were supposed to have last year.
The boss went to a road safety council meeting this arvo so I will ask him on Monday if anything was mentioned.
With the tunnel in small concrete sections that are all the same size... it isnt hard for the cops to work out what speed any vehicle is travelling as the tunnel is monitored 24/7.
With the new laws enabling anyone to show traffic police video evidence... all the tunnel security would have to do is show the cops a video of a car alledgedly speeding... the cops could determine the speed by how many sections the car is passing over a certain time frame, and then issue an infringement.
This new law together with tunnel security/police co-operation, has effectively made the existing tunnel security system, a speed detection system aswell.
Ive noticed for the first time, so I assume its new, on North bound 3 separate mounting brackets on RHS as you drivng thru the tunnel... maybe the beginning of the end :O
EDIT: And same for south/east bound.
Edited by infamous_t
if you speed in the tunnel (exceisvly)(SP?) you will get in trouble as they can work out how fast you were going.
anyways, i noticed a few weird things in the tunnel today, it looks like some sort of air monitoring device. I wouldnt be suprised if they eventually fit fixed speed camera's.
Not that i get a chance to speed in the tunnel, the speed limit is 80 and the second the retards hit the tunnel they slow right down to 60, then speed up as soon as they exit. shits me real bad.....
i have never understood why everyone slows down in a tunnel like you said. annoys the crap out of me
Probably because there are walls either side of them, and Perth drivers are shit scared when anything else is close to their cars. Like merging points, another car coming in to the same area automatically means heavy on the brakes & come to almost a complete stop.........
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
