clean with a wire brush and then use metho to clean off any residual dust. it shoudl stick then but at the same time, if there was any trace of water in the spray can when it was manufacteured it would bead up to.
try some brake and parts cleaner from an auto store
... that sounds like a good idea.
When I did mine, i used a wire brush and detergent, and scrubbed for a long time. That worked ok.
If i was to do them again, i'd try some brake cleaner, wire brush, and then finish up with some Prepsol/Wax&Grease remover.
Read the paint can to see if a primer is needed.
With the Duplicolour stuff, i used a Duplicolor metallic primer.
Edited by Trav33
you also more than likely have built up residue from tyre shine stuff over time which does not mix well with paint, I sand blasted mine which is overkill but I had them apart at the time. just give them a super good clean and you will be fine
Morning all,
I had my wheels off recently to paint the calippers on my car. I bought the proper calipper spray but when i sprayed it on it beaded and wouldnt stick. Do i need to prime the caliper or something????
Cheers!adam
As said you need to do more prep work before applying paint, have a look at Paul's DIY thread :O
i just did mine yesterday..came up perfect..
just clean the shit outta ur calipers..
<a href="http://imageshack.us"><img src="http://img518.imageshack.us/img518/9396/calipers001tx8.jpg" border="0" alt="Image Hosted by ImageShack.us" /></a>
<a href="http://imageshack.us"><img src="http://img300.imageshack.us/img300/1608/calipers002uc9.jpg" border="0" alt="Image Hosted by ImageShack.us" /></a>
<a href="http://imageshack.us"><img src="http://img513.imageshack.us/img513/6906/calipers003hb3.jpg" border="0" alt="Image Hosted by ImageShack.us" /></a>
    • No requirement for JDM vehicles,  which the 33 is, maroney label only needed in the US market for new cars I believe (Federal law stuff) Google knows all
    • Hopefully you can just unbolt them, thank them for their service, then bin them and not replace them Apparently the sensors like to set them off with only minor impacts at low speed It looks like they do a delete kit for some of these, but, it is costly
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
