hey guys,
my battery on my r32 gts-t has finally died, due to draining it flat many times over.
i replaced it yesterday and just today i noticed ive got battery acid (correct me if im wrong) on my cooler piping.
im pretty sure this occurred just before i changed the battery, as ive had no probs with the new battery.
seems that its eaten into the piping.. but im not sure if it will continue eating into my piping, and what to remove it with?
heres a pic of the engine bay
a close up of the pipe
under the battery tray
and the mark it left on the concrete
thanks for your help guys :)
https://www.sau.com.au/forums/topic/170126-battery-acid-eating-cooler-pipe/
Ill 3rd both the above arguments .. alkaline to kill acid.. :O
baking soda is avaliable in cooking section of super markets .. or hit up your old lady or next door granny
Id assume your polished or stainless will be stained tho :D
For future reference it can be flushed with water on contamination and it will dialute the acid .. but dirt or sand will also work well as a quick fix ..
Edited by DECIM8
as above, but dishwashing liquid + water does same, and usually more accessable for ppl.
Baking soda is much better, because it will cause a chemical reaction and neutralise all remenants of acid.
If you have exposed metal, spray some paint on it afterwards to prevent rust.
thanks for your help guys :stupid:
i used water and baking soda with a scrubber to apply it
it was getting off the surface crap and i could hear sizzling
i think it worked because the surface is smooth again, but is there any way to get the stains off?
Edited by dmr
thanks for your help guys :ermm:
the sizzling was the chemical reaction taking place, the basic solution neutralising the acid
unfortunately the acid would have etched the surface of the cooler piping, so it will need to be polished again to remove the stains
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
