hi guys,
the last few times i have filled my tank FULL i get a really bad fuel smell in the car. i have looked for leaks in the engine bay and looked under the fuel tank but nothings leaking.
its weird coz the smell only lasts like 20min of driving after i've filled up and then its gone like nothing happened, and i've been filling up at the same servo and using the same type of petrol for a year and a half.
- i did replace the fuel filter bout 2 months before this started happening so i've ruled that out as a cause.
- fuel caps in good cond.
- still getting the same fuel economy i always did
can any1 help me out, whats causing it?
Edited by tigr33
https://www.sau.com.au/forums/topic/170266-fuel-smell-inside-car-r33-gtst/
If you fill up when the car is already hot a lot of pressure builds up in the tank and seeps past the rubber seal for the fuel pump, the fumes then enter cabin. however if you can't smell any signs of fuel fumes in your boot and you can under the bonnet it will probably be a deteriorated hose or loose hose clamp.
Rubber seal on tank lid, Just do the Match test LoL that will determine where its coming from :wub: Just kidding If its only when its on full, most likely over full it be the rubber seal in the boot id reckon
Good luck
A
Guest
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
