  • Replies 41
Whats done to the car ?
well so far...
* Splitfire Coilpacks
* Custom Extractors
* Trust Stainless Steel Catback Exhaust
* Impul Body Kit
* Window Tinting
* Koyo Wheels 18"
* 7" screen
and a few little bling bling items throughout the car
and hopefully before Autosalon.....
DBA Slotted Rotors, Brake upgrade (to R33 4 pot calipers), Underbody Neons, Graphics
:O
https://www.sau.com.au/forums/topic/170270-powerfest/#findComment-3146681
well so far...
* Custom Extractors
* Impul Body Kit
* Window Tinting
* Koyo Wheels 18"
* 7" screen
:laugh:
>_<
https://www.sau.com.au/forums/topic/170270-powerfest/#findComment-3146773
    • Thanks GTSboy. I will inspect the valves actually, is this something I can do while they are still in the head? The block/bores don’t look bad to be honest hey, I can still see the cross hatches in the bores and they still measure 86.5mm. I’m not sure how to measure the installed ring gaps but I will do that and take it to someone who can.
    • I’ve had the same headache with my lowered car, scissor jack first then floor jack every time. Ended up grabbing an extra-low profile aluminum jack (about 70mm entry height) and it finally slides under the lip without drama.
    • No sync errors , i have installed AEM disk will return original 360 slot disk and check if there’s any one with running AEM disk could share setup
    • Its been a while! Finally thought to do something on this car, so here we go. This will be a slow burning, multiple posts as I spend 0.5-1hr a day on this job, over multiple days... Full set of GKTech suspension arms!   Step 1: Buy Arms, done! Step 2: Start removing stuff. HICAS was easy. Rear suspension arms are now gone, they were a bitch but breaker bars with long handle extensions, 2 1.5hr slots later, stock arms are off! Next step, remove the hubs and take them to work to press out the bearings and bushings!
