yes and no... im pretty sure the exhaust housing on the 33 was larger... so even from a stock 33 turbo, it wouldnt be much of an upgrade... especially if you have to pay for it...
then theres the oil lines and what not, i have no idea if it would perfectly fit up...
If your paying any sort of money for it, get a high flowed 33 turbo from slide, $890 delivered i think...
hows $200 fully recoed sound never run? My turbo is ok but i was wondering what this might do. The guy has no idea on specs and is cheking it out, so i will post once i get it.
But i think the Rb20 trubo has same size banjos as the Rb25??? no???
Its neither..
Definitely not an R32, R33, VG30DET, rb26 anything...
Its some sort of garrett gt25 or gt28 turbo. Does it have the regular T3 flange?
BB turbo's are not servicable. So its not reco'd. It will be either new or used.
When so called reconditioning turbo's they use the old housings; throw out the old center and replace it with a new item.
So essentially a bran new turbo minus the housings which is not to be concerned about anyway. :bunny:
definatly a T3 turbo to manifold flange, and different for the back but yet to confirm details. Either way it has never ben on a car since being recoed or rebuilt or what ever.
I have been told it will fit the R33 but have to wait to confirm details.
thats a stock T3 from a 33...
and by the looks of both wheels being steel, the bore size being right at the edge, and the centre metal nut being cut for balancing... i would say its a highflow R32 turbo :bunny:
Incorrect. It's NOT NOT NOT an r32, 33 or 34 turbo. this has 5 bolt dump pattern. the gtst turbos have 6 bolt. Looks like it's either a gtr turbo or a t25/t28 from a silvia or something.
That is about as far from a stock nissan turbo as you can get.
r33 turbo says nissan 45 v on the comp housing.
r ugly poo says nissan motors 16v
Edited by MANWHORE
Hey wogs
Well, once you get it bolted on etc, it will probably be an upgrade (being a garrett turbo with steel wheels, you shoudl be able to run more boost).
But we're not sure if it even is t3. If it's not, it won't bolt up to your mani.
You'll definitely need a new dump pipe (or at least have the flange changed on it).
You'll most liekly need new oil/water lines (like other garett turbos) i.e. if it even is watercooled, otherwise just oil lines
IC piping may or may not bolt up (looks like it should)
thanks guys, i'll await the specs, but for $200 if it is ok, it's a steal, eaven to sell it again. LOL.
Yeah thanks all, i simply have no idea what it is. I rang the guy an i should know within a couple of days exact specs.
hey man, does it look like i know everything about turbos? do you think its my main area of expertise???
i was basically saying that it wasn't a 33 turbo, and being as how he gave a choice of 2, i took a stab in the dark... and missed :P
:) knew someone would come and correct me :bunny:
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
