  • Replies 222
Posted Images
She's great Noel, your a lucky man...
But other than that I give you 2 gold stars for your engine knowledge, your general knowledge is far higher than I first gave you credit for... :P
he gets it all from me :D
My economy is awesome....1 tank of fuel lasts me like 2-3 weeks easy. I found out that by driving a work ute instead of the skyline, my fuel economy has improved and my wallet is fatter! :P
donate to the Get Shane's Car Back On The Road fund and eleviate some of that fatness :D
BS...you get it from me. He used to get it from you but then he found out you don't listen to me so he bypasses you now and rings me instead.
And sif you need funding...you live in the Switch! don't the government fund you guys?
hahaha yeh government funds the switch and it locals..lol.Give centrelink your sob story, your a full time uni student lives away from home, you have kids with no partner and your 1/8th aboriginal, while at the same time working a full time job, and then doing weekend work for cash. If i lived in the switch thats what i would do...youd be on like 2g a week easytown.
And let's not forget...that's almost a dry sump setup.
Unless you do what Shane did and buy a pump that's come off a NASCAR. Then the pump is only about $350 but it's already had 10 hours at 8krpm
lol... still like u to fine me someone who put a RB20 into a SR20 powered car. besides SR halfcuts are 3k+ wher as RB20 are 2k or so..
lol who was complaining about std SR oil distribution... look at the RBs haha.. rev it for too long and all ur liquid gold is in the head.. booyah.. bye bye big ends.
.. sound similar to ur GTR shane.. big end failure.. BANG
Really? mine doesnt have that problem. I got a nifty little oil pump that hangs off the side of my block, where the a/c would normally sit, infact the only oil in my engine is whats running through its veins doing its job, straight afters its done what it needs to it gets sucked out. My big ends are fine too.
Sr's biggest fault is their stupid rockerarm/camshaft design, nearly as stupid as pushrods in v8's...and two valves per pot....and because i hate chrysler/dodge stupid hemispherical combustion chambers!
Don't forget the alloy block is a bit of a nancy boy, it breaks to pieces after about 700hp. Then, of course, you have all the issues with the SR oil pumps. They rattle their arse off before taking a hike.
relays, pfffft who needs them :D
dude if i was even 1/50000th aboriginal i'd be claiming everything i can :P
if it works (which it should) who gives a fark where it came from/how old it is. ur just cut ur getting reamed for a new one :P
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
