sounds a bit like how mine wasa
my car used to feel sluggish at full throtle but at 1/2 or 3/4 it felt fine.
it could be running very rich and also if u havent yet gap ur plugs to .08 it cleared
all my flat spots.
hope it helps...
how do you expect fire to come from the engine if it has a cat in it?
a cat is like a sponge made of a hard clay... aint no fire getting through that...
i sugest you but a plumb back bov on there, check your intercooler connections for leaks in the line, and put a cat in your exhaust...
Chances are your coilpacks are shagged, when i got my 33 they were stuffed and flooring it through tunnels sounded like a machine gun, i had the exact same problems though, loss of power, shotgun bangs etc, tape up your coilpacks as per the DIY in the tutorials section or do it properly and buy splitfires. Changing the plug gap will only mask the problem.
Edited by JayTay
Won't be the coils. Try replacing the atmo BOV with your stock BOV if you still have it. If that doesn't work it could be any number of things but it's only going to be fuel related as you need lot's of fuel for flames to make it past the cat and mufflers. Could be any of these+more: faulty afm, leaking core, piping or hoses, fuel regs crapped it's self, could have reached r&r...
I've seen flame go through a cat.
Mine did it once.
Do it too much and the cat WILL collapse/burn out.
Most likely, you've got an air leak somewhere, and under boost you're letting air escape (Meaning rich AFR)
This will be AFTER the turbo, before throttle body most likely.
Mine did it once.
so starting from cheap things to check to expensive i should. check cooler pipes. check spark plugs and gaps?
what else
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
