sounds a bit like how mine wasa
my car used to feel sluggish at full throtle but at 1/2 or 3/4 it felt fine.
it could be running very rich and also if u havent yet gap ur plugs to .08 it cleared
all my flat spots.
hope it helps...
how do you expect fire to come from the engine if it has a cat in it?
a cat is like a sponge made of a hard clay... aint no fire getting through that...
i sugest you but a plumb back bov on there, check your intercooler connections for leaks in the line, and put a cat in your exhaust...
Chances are your coilpacks are shagged, when i got my 33 they were stuffed and flooring it through tunnels sounded like a machine gun, i had the exact same problems though, loss of power, shotgun bangs etc, tape up your coilpacks as per the DIY in the tutorials section or do it properly and buy splitfires. Changing the plug gap will only mask the problem.
Edited by JayTay
Won't be the coils. Try replacing the atmo BOV with your stock BOV if you still have it. If that doesn't work it could be any number of things but it's only going to be fuel related as you need lot's of fuel for flames to make it past the cat and mufflers. Could be any of these+more: faulty afm, leaking core, piping or hoses, fuel regs crapped it's self, could have reached r&r...
I've seen flame go through a cat.
Mine did it once.
Do it too much and the cat WILL collapse/burn out.
Most likely, you've got an air leak somewhere, and under boost you're letting air escape (Meaning rich AFR)
This will be AFTER the turbo, before throttle body most likely.
Mine did it once.
so starting from cheap things to check to expensive i should. check cooler pipes. check spark plugs and gaps?
what else
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
