  • Replies 67
My excuse is, I already signed up for show and shine
Any skylines that show up on the day that are not part of the show will be fined $20 for members, $30 for non members!!! so its cheaper to just enter the show !!!!!!!!!!!!
(disclaimer:you may or may not be fined)
Yeah come on peeps!
Our Show 'n' Shine isn't like your usual import Car Show Event.
It's all about showing the community of Skylines Australia and having fun with fellow enthusiasts.
So get off yo asses!
And get to the thread and enter today!
You can even use your credit card!
Yep its a great fun day to enter your car and chat with other skyline enthusiast.
Never know maybe see someone with mods you like, can walk over and ask where they got there parts from and so forth.
Enter show and shine or die!
It is NOT autosalon, I dont care if your car is broken, or scratched or dented...if it's a skyline I want it THERE!
It is a excellent show and it will be great fun...See you there!!!! :)
P.s My GTR has dents and scratches and needs a respray but I am still entering, to show my support and try to have the most skylines in the one place EVA!
It is NOT autosalon, I dont care if your car is broken, or scratched or dented...if it'ss a skyline I want it THERE!
It is a excellent show and it will be great fun...Hope to see you there
:D
Then i must die........ :)
If we had of got our act together down here it could of been a good road trip..
how will i die if i don't enter?
will it be in my sleep? in a car crash? will I drown?
I just want to consider my options.
considering I don't own a skyline anymore, will the die option still be applicable to me?
Yes Liz, it will :)
We will decide the dying factor :D
Both my cars will be there hopefully!
And the 31 will have some "special mods" coming... hahaha
So if your car is a...
show car
track car
stock
modded
clean
dirty
new
old
riced up hektikness 2NV
or a dirty drift/rally pig
get ya arse into gear cause all those types are welcome!!!
You'll die of a broken heart... or shame... or consumption.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
