  • Replies 64
Posted Images
Thanks for the comment Guys... :thumbsup:
The Ganador Mirror is nice, but then everyone has it. So I took the Mine's Mirror because they are the ONLY company with REAL Carbon Fiber.. The Ganador mirror is painted carbon, and I am not going to pay all that money for a Carbon LOOK mirror. :nyaanyaa:
This is the full list, I am sure I miss something in there. :action-smiley-069:
Power: 520 bhp at Hub @ 7500rpm (1.3bar) Dyna-Pack Proven (590bhp @ flywheel)
Expected: 650 flywheel bhp @ 1.6bar (waiting for a re-map)
Engine: RB26DETT
HKS 88mm forge pistons
HKS H-Section Con Rods
HKS 1.2mm Metal Head Gasket
HKS T04R Stainless Steel Manifold
HKS T45S Turbo (Same as Garrett TA45S)
HKS 200mm Air Filter with Red Element
Billion Heat Reflective Wrap
HKS Polished Hard Pipe Kit
HKS Type-R Front Mount Intercooler
HKS 272 Step1 Camshaft (In/Ex)
HRD Cold Forge Adjustable CAM Pulleys
HKS External Wastegate with Screamer Pipe
Greddy Type R Blow Off valve
HKS 75mm Downpipe
Custom Made 75mm-90mm Decat Pipe
Custom Made 90mm Straight Exhaust (No Centre Silencer)
Apexi Titanium Slide Finisher
Apexi Active Tail Silencer
KYB Dual Entry Fuel Rail with Earl Braided Steel Line
HKS 6x 680cc injectors
HKS 280lph Fuel Pump
HKS F-Con V-Pro
Blitz SBC-ID III Controller
Blitz R-Vit monitor
Apexi RSM
Greddy Oil Pump
Trust Sump Extension
Grex Oil Cooler with Remote Oil Filter Relocation
Splitfire Direct Ignition Coil pack
Splitfire Direct Ignition Bridge
Impulse Performance Uprated Aluminium Radiator
Tomei Engine Oil Cap
Nismo High Pressure Radiator Cap
Stainless Steel Oil Breather Tank with Braided Line
Pivot Blue Raizin Grounding Kit with Voltage
Stabilizer
Transmission
OS Giken Uprated 1, 2, 3 gear set
HKS Twin Plate Clutch
C's Short Shifter
Nismo 2-Way LSD
Chassis
D2 Racing RS Pro Coilover Suspension with Remote Gas Reservoir (Separated Compression and Rebounce Adjustment)
D2 Racing Rear Camber Arm
Tein Front Traction Rod
D2 Racing 8 Pistons Front Brake with 356mm 2-piece Brake Disk
D2 Racing 6 Pistons Rear Brake with 356mm 2-piece Brake Disk
D2 Racing Stainless Steel Braided Brake Line
Nismo Master Cylinder Stopper
Nismo Front Strut Brace
Cusco Rear Strut Brace
Do-Luck Rear Cross Bar
HRD HICAS Cancel Bar
Asso Interspeed Centerlock Wheel (limited production of 100 sets)
Bridgestone Potenza RE050A (265/35/18)
Exterior:
TBO Front Bumper
TBO Side Skirt
Do-Luck Rear Bumper
D-Speed Front Grill
D-Speed Rear Wing
Yanack GT Front Wing
Yanack GT Rear Wing
Mine's Dry Carbon Wing Mirror
R32 N1 Headlight
Econ H4 Hi/Lo HID Kit
D-Speed Smoke Corner Lenses
Speed-R Carbon Fibre Bonnet
ARC Titanium Cooling Panel
Top Secret AeroCatch Bonnet Pin
R32 LED Rear Tail light
Tomei Rear Tail Light Cover
Window out Repaint in Lamborghini Grigio Avalon
Interior:
NISMO Sport Bucket Seat
MOMO Trek R Steering Wheel
D2 Racing Ball Bearing Steering Wheel Quick Release
Razo Drift 150 Brushed Aluminium Shift Knob
Razo GT Brushed Aluminium Paddles Set
Pivot 80mm F1 Tacho with Sequential Shift Light
Pivot 60mm Gauge for Boost, Oil Pressure, Oil
Temperature, Exhaust Gas Temperature
Pivot Centralized Peak Hold Button
Re-Wing Centre Dash Pod
Trust A-Pillar Gauge Pod
Dugan Racing EL Dash Clock
Stainless Steel Dash Clock Surround
Skylab Traction Controller
Pioneer Stereo with some Sony Speakers
Edited by Nocturnal
Thanks for the comment guys.
As for laradly, what you said makes perfect sense.
This R32 does not flow, it wasn't ment to flow. And this is where it stand out from the rest of the R32.
However, the Standard R32 does have a lovely curve, and alot of die hard R32 lover want to hang me for doing it to their pride... :worship:
Thanks for the comment on the engine though. :)
  • 4 weeks later...
Hello Guys,
I know you guys ask for a video of the car, but never really had a chance to take it.
Decide to take the R32 for a dyno run to make sure the increase boost pressure isn't causing lean condition.
It was done at a show last weekend and one of the local tuners (THOR) took 2 Dynapack with them awith all the gears.
The first run made 597bhp at rear hub at 1.55bar (have to disengage the 4WD because Thor only have 2 Dynapack), but the top end is a bit leaner then I like.
The Second run made 573bhp at rear hub at 1.47bar and that was much much nicer! smokin.gif
This is a video of the first run, not the best quality, but sounded wicked in the tent. Keep an eyes on the crowd... Everyone scramble as soon as it hit full boost!!! chuckle.gif
Also, I give up on trying to figure out how to embed the video, if anyone help teach me, that would be great. thumbsup.gif
My mate took this picture last night... This is a Teaser I was told.
It looks like I just landed from space or something. I will get the proper pictures later this week, I'll post them up when I get it.
Welcome to Earth!!!! :laughing-smiley-014:
Thanks , the purple backdrop I think is "slightly" photochopped...
I think the background is more blue then purple.... Here is a couple more that my friend send me...
The Front Shot
The Rear Shot
The Underground Shot :)
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
