hey guys im looking at making a stainless intake and i need to replace a small piece of shitted cooler piping and i was just wondering if anybody could point me in the direction of a stainless steel pipe supplier that they know of/have dealt with? preferably south side of brisbane but yeah anywhere around bris is sweet. cheers
https://www.sau.com.au/forums/topic/171389-stainless-steel-pipe-supplier/
Midway is the s/steel supplier in Brisbane. May not sell short lenghts. 32872811
I just bougth 18m of 316 50mm mirror finish tube for $37.40/meter
Or try Tube Sales 3287 2917, they sell by the meter
man i work in a truck exhaust shop and have 100's of metres of every size up to 10" let me know what u need and i'll give u a price... SAU discount
im guessing u can also get a range of bends aswell?
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
