Hey Peoples
Just getting the Stereo on my car figured out,
I want to have a 10 or 12" subwoofer with an amp for the sub and another one for the speakers.
My dilemma is that I don't want to waste to much boost space and I hate those pre-made sub boxes things that you chuck in your boot and go.
So I need some idea and photo's of different types of boot installs on Skylines.
I have an R34 but I'm guessing most skylines have very simlar boots.
Cheers
Josh
https://www.sau.com.au/forums/topic/171685-boot-install/
Hey Peoples
Cheers
Josh
Check out this thread..
http://www.skylinesaustralia.com/forums/in...=159050&hl=
If you search you should find some other threads
You can find/get a lot of good info here.. ( formerly Car Audio Australia (CAA) )
http://www.mobileelectronics.com.au/forums/index.php
https://www.sau.com.au/forums/topic/171685-boot-install/#findComment-3165660
Hey mate.. 33 has a bigger boot but r34 is a pain in the ass .. majorly because it has the step up in the boot for the fuel tank ..
theres my crap amp rack .. working on sub enclosure .. might get a pro to do it .. just cause im starting to be lazy
https://www.sau.com.au/forums/topic/171685-boot-install/#findComment-3165830
whateve... it had better be done for SNS :O or at least entered... i dont want the pres hurting you :P
my car is stripped at the moment... the boot is to bare metal, seats are out, dash is... put back in so i can move it... but it was out...
there are wires EVERYWHERE cause im re-wiring everything, adding 2 new subs in custom boxes, new amp mounts... basically, i have saturday sunday and monday to do most of the work, then afternoons... and it gets detailed on friday... :D
ill be pissed if its not finished...
https://www.sau.com.au/forums/topic/171685-boot-install/#findComment-3165907
I hope its finished because I can see those mofos are going to give the thunder a run for its money ... the power that they'll need will even give lightning a go :O
chix will love ur back seat... vibrations :P
Oh and a blew another fuse the other day ... wtf?! common it was the speakers that did it this time tho.. i wonder if im going to go deaf..
Im not going to make it to sns im working :D
Edited by DECIM8
https://www.sau.com.au/forums/topic/171685-boot-install/#findComment-3165936
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
