I have traced the wire from an aftermarket 3-stage switch which is mounted on my dash beside the rear window demister, which leads all the way back to the rear left boot compartment, beside where a 6-stacker could usually be mounted. Havent had the opportunity to pull off the boot lining to look at what it actually goes to, but just thought i would ask to see what is actually in there?? Anyone have any ideas?
there looks to be two or three different components in there?? IDEAS
Cheers,
Tim
When you say "left" do you mean drivers or passengers side?
Because on the passengers side, in the boot compartment, well hidden under a butt load of stuff is the ATESSA Controller ECU, which controls the AWD..... might be a switch to put into RWD? Which is not recommended either. Do a search to find out why :rofl:
Nah no TV, dot think the Autech ever got a TV did it? will get some pics, but i'm pretty sure it would be something to do with the Atessa......i have tried switching the switch and seeing if it effects the torque gauge on the dash but it seems to be same in every mode......??
Managed to pull the boot lining out today and found where the lead went.....it went to small silver box behind the Attessa System. The reason the switch was not working before was becuase it had come loose from the connection so i reconnected it, all working now.
Went for a quick burn and just from the torque split guage, it seems that with it one position, there is minimal torque to the front wheels (but these is some, NOT RWD) middle setting is as per normal attessa control, and then top position is heaps more front torque and results in a lot of chatter when taking off quickly when the front wheels are struggling for grip.
I guess that i would be much better off just leaving it in normal position, to make sure i dont end up with any problems associated with driving in RWD mode??
Yeap, looks like you have an atessa controller installed, but as with the R33/R34 atessa, evenwith it turned off, there is still some torque which is transfered to the front. Leaving it off will eventually result in a costly gearbox rebuild as it'll burn out the clutch packs, or so I have read.
Yeap - but it will stuff the transfer case, not the gearbox which is worse because the auto is fairly common whaereas the transfer box isn't.
Incidently I recently found out something interesting about the auto - it has normal bands for 1st and 2nd, but runs wet clutches for 3rd and 4th (OD)
So i;ve been doing a bit more investigating into the effects of hte switch, It seems that no matter what setting i have the switch in, there is the same levels show on the torgue Guage. WHen i switched the attessa to minimal front torque, i almost spun the car around a corner ie no front grip, ut the guage still showed nearly 50 Kg/cm of torque. I asssume the guage is rigged up somewhere before the attessa system takes over? any idea?
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
