  • Replies 111
Thanks but I've got a complete GTR, thats all that is missing :)
They look pretty mean without the cover anyway, I only want it for originallity and for car shows.
Let me know if you want to seperate.
Cheers!
Gagz
PS: When I say Coil/Valley cover, I mean the same thing.
Edited by R31 Gagz
is the suspention still available
yes it is mate with the suspention i might do it as a package 4x hks coil overs 2x front after market top control arms 2x after market toe in toe out bars what would you offer me for this award winning combo
sold parts are:
exorst the hole lot
steering wheel
front bar
both guards
bonet
rolecage
wireing loom
hks map
link ecu
make an offer guys and thats to the ppl that have called and come picked up what they have needed u guys are great to deal with
Edited by ANK
700 firm
http://www.myevo.com/HKS_Hiper_1.jpg
thats a link to a photo of the coil overs i have that is a photo of the front ones the back are the same model just for the rear offers? or ball park figure?
Edited by ANK
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
