Let the member benefits keep coming!
lf you thought you couldn't possibly get any more value out of being a member of SAU - Victoria,
think again!
The committee is pleased to announce our latest supporter
http://www.skylinesaustralia.com/forums/in...=0#entry3166167
Thats right people. 10% off any quoted price for wheels, tyres & mechanical servicing.
For most of us, the discount on 4 new tyres will cover the cost of the years SAU Subscription!
This only applies to CURRENT SKYLINES AUSTRALIA VICTORIAN members....so if you have let your
membership lapse, or needed an extra reason to become one, here is your chance. For information about membership & member benefits
click here ----> http://www.skylinesaustralia.com/forums/in...showtopic=60590
To Sign up as a member click here ----> http://www.sauvic.com.au/download/SAU_MembershipForm.pdf
https://www.sau.com.au/forums/topic/171849-show-your-sau-membership-card-save/
  • 3 weeks later...
AWESOME!
Your sponsored by "The error returned was:
Sorry, the link that brought you to this page seems to be out of date or broken.
lol
Indeed Ash is right, your membership expired a million years ago. :)
I actually sent you another renewal notice by post in early June, after your email bounced.
If you want to renew just put $ through and let me know: [email protected] :)
Cheers!
~Kaz
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
