Modded my boost solenoid, So just a quick post with some 0-100 times on my stock S1 RS4. All recorded on a g-tech at night (canberra = cold)
Before mod (stock boost cut until 4500 rpm)
Run 1: 8.28
Run 2: 8.37
Run 3: 8.19
After mod (full boost throughout range)
Run 1: 7.31
Run 2: 7.38
Run 3: 7.29
worth your time!
Cheers!
https://www.sau.com.au/forums/topic/172290-boost-solenoid-mod-0-100-times/
has anyone gone to the effort to extend ( what I beleive ) is an easy mod one step further?
would be good if you could get a 2 way switch to allow you to go between the 2?
Ie .. stock setup - low boost till 4000rpm
then full boost from 0 - redline
could be a good thing to do
not worth the effort, leave it at full boost, and control it with your foot. :wub:
Just the standard ground the solenoid so it's open all the time (or just bypass it..) but as far as having a switch for it.. I don't see a lot of point, as it's much more responsive with it fixed, and uses a reasonable amount of less fuel. More midrange = less right foot.
But was good to see a difference in numbers, not just feel. It was mainly off the line where it made the difference. Up to 50 kph or so was HALF the time. I also tried one run with loading up the stall but the brakes couldn't hold it under full throttle.
fun stuff anyway :) I would have done some 0-400m but not a lot of ACT roads where doing 150kph recommended..
I don't suppose you could follow this up with some numbers on your fuel economy?
Anywhoo, thanks for sharing the lurve :)
When I did the mod I went from about 390k a tank to 450k a tank, but it's all really down to driving style I guess.. I'm pretty easy on the car, doesn't spend much time above 3500rpm, but doesn't have to now.. before you really had to wring the neck out of it for any sort of performance, so effortless now. Different car! Even feels better down low than my TT 300zx which is 3L and has 2 turbos (manual)
The mod is just in the sticky section under DIY.. I think it's called full boost modification or similar.. 5 mins work..
its called rb25 boost solenoid mod i think.
essentially you ground the solenoid, so its always open (the ecu opens it at 4,500rpm, so you have 5psi boost to 4500rpm, then 7 over that)
you can either ground the solenoid, or just rip the thing out and join the 2 hoses (make sure you dont use a joiner that will restrict the hose I.D. otherwise you might get too much boost, ideally use a single piece)
very good, cheap mod to perform on the rb25. :)
very good, cheap mod to perform on the rb25. :worship:
why not buy a manual b/c and try ten psi, even better :)
mate not a chance in the world anyone would ever notice even if it was illegal...you cut one wire and ground it to the chasis.
the beauty of this mod is it gives you power in the midrange, doesnt affect top end (and therefore should be super safe for the motor). And cost is about 10c...5cm of wire and a eye terminal
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
