hey guys
i just signed up, i have an r33 and i want the perfect bov. i have no idea what to get. i have heard one going around that flutters. has anyone heard or know of this. all suggestions would b helpful.
respect.
https://www.sau.com.au/forums/topic/172514-which-bov/
Well, I'm not sure if this is a joke or not but..........the flutter comes from not having a blow off valve. Just take yours off (if you actually own a car with a turbo) and plug it up. But the lag between gears pisses me off so I go back to the trusty HKS SSQV. Please do searches, questions like these have been answered sooooo many times.
https://www.sau.com.au/forums/topic/172514-which-bov/#findComment-3175320
Hi mate.
The only such thing as a perfect BOV is a re-circ one. And sounds like you dont want that.
Please have a search around.
You'll find most of your questions will probabl have been asked once or twice before :D
i did try looking but i didn't find them. thanks anyway
https://www.sau.com.au/forums/topic/172514-which-bov/#findComment-3175994
hey guys
respect.
You will hate your atmo bov once your car starts stalling on freeways, traffic lights and other busy places.
Been there done that.
If you really want to waste your money on a bov, get a GFB Stealth fx. They sound good and can be adjusted manually.
https://www.sau.com.au/forums/topic/172514-which-bov/#findComment-3176170
He's said he has a PFC in his other thread. If you put an atmo bov on you can tune out all the negative effects that it has on the stock ecu.
Edited by KeyMaker
https://www.sau.com.au/forums/topic/172514-which-bov/#findComment-3176172
Its true. I bought my car with an aftermarket atmo BOV (the sort that goes Psssshhh)
Sure as my first turbo car it put a grin on my face but trust me, I wish I had the stock re-circ BOV handy. Doesn't look all that cool when you pull upto a set of lights and promptly stall. Also causes overfueling when changing gears (loud pops)
The stalling was annoying me so much I went down and bought a piece of rubber hose and some cable ties and did a home DIY job of MAKING my bov plumb back. It kinda worked, doesn't stall nearly as much now but it still has issues, the rubber hose doesn't make the best seal around the BOV vent hole so its still venting about half of it.
Its a pain in the ass I tells ya.
And having driven my car for a year or so now with the atmo BOV, you get sick of it pretty quickly. Do I prefer the psssh noise? I guess, it does turn heads. Is it worth the stalling issues? No way.
Not having ever used the stock BOV (that vents back in) I wouldn't know for sure but I would assume it would make some noise anyway would it not?
https://www.sau.com.au/forums/topic/172514-which-bov/#findComment-3176185
I just searched using your own word "flutter"
http://www.skylinesaustralia.com/forums/in...lite=%2Bflutter
Seems there is a few results around :D
If you need help using the search function, drop me a PM.
https://www.sau.com.au/forums/topic/172514-which-bov/#findComment-3176359
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
