I've got a situation where if I hold WOT from 3000rpm to redline in 2nd gear on a FLAT surface, i get max about 35 knock.
However when heading up a very steep hill, doing the same as above i get 60-80 knock and obviously the engine light flashing at me :(
Is there a simple way to fix this? Please bear with me as I'm relatively new to PFC tuning! :)
Cheers
https://www.sau.com.au/forums/topic/172669-pfc-tuning/
Thanks for the reply!
Im not sure what you mean though. How can you see the knock levels when you are on the map trace screen? What mode does the map trace need to be in when doing the run? There is a mode that just floats the cursor around the screen, and one that looks like it traces the line across the screen as rpm/load increases.
Apologies for getting back to basics, as I said - I'm a noob when it comes to the tuning side of PFC :)
https://www.sau.com.au/forums/topic/172669-pfc-tuning/#findComment-3177839
It's been on the dyno for a tune, and then once for a touch up. It's only one small condition where it knocks so it's hardly worth paying money for it if I can fix it quickly with the help of forum members :kiss:
https://www.sau.com.au/forums/topic/172669-pfc-tuning/#findComment-3177963
Apologies for getting back to basics, as I said - I'm a noob when it comes to the tuning side of PFC :kiss:
Short answer: you can't.
But you can see the light on the dashboard.
"There is a mode that just floats the cursor around the screen"
Which is what you are after.
Find the cell eg 10 across & 15 down that the cursor is in when the dash light flashes.
Then go back through all the menus to find your ignition value for that coordinate. Suck a degree or two out of it. Problem should go away or reduce if you have the right cell.
A word of warning. It is best to write down all the fuel & ignition values BEFORE you start. Then you can always put things back to normal.
A better solution is to take it to a dyno & get it done properly. Particularly if it is WOT because you can't diagnose fueling issues on the road.
https://www.sau.com.au/forums/topic/172669-pfc-tuning/#findComment-3177987
covered in great detail in the powerfc faq (in my sig)
spend some time reading and learn how to debug knocking and tune it out yourself
its pretty easy and doesnt take long. it even lists each step and what you need to do it
(the link is in my sig)
https://www.sau.com.au/forums/topic/172669-pfc-tuning/#findComment-3178008
Just a quick question regarding knock, rather ask it here than make a new thread. I had my power fc tuned a month or so ago when the car had primarily Shell V-Power racing (100 octane) in the tank and the knock levels would not go over 30 at any stage.
Now that Shell have altered their pricing strategy and V-Power racing is set at 154.9 I have been putting V-Power (98 octane) in it , my problem is that the knock levels have gone way up when it is under load, I actually hit 115 in the cold the other night.
Obviously I have been babying the car since then but should I pay for a whole new tune from my tuner ($300) and should an octane drop of only 2 effect it that much? It's really shitting me as I can't believe a lazy 2 octane could make such a difference. I had a look at paulr33's PFC guide and while being informative, I know jack shit about reading the map thing and don't want to make things worse by playing around with the timing.
Any advice or thoughts would be appreciated even if they are just "take it back to the bloke who tuned it."
Thanks
https://www.sau.com.au/forums/topic/172669-pfc-tuning/#findComment-3184135
You could probly just leave the tune how it is. under normal driving conditions (if your not going to go into boost) dont worry about it. IF you do plan on giving it some stick then go into setting and then inj/ign and set the timing to -5 deg. This will take out 5deg of timing from the WHOLE map.
Remember once you turn the car off the setting will be reset back to 0 so you will need to do it again next time you plan on giving it some stick.
if you have troubles finding it and need someone to walk you through it over the phone pm me
Thanks
https://www.sau.com.au/forums/topic/172669-pfc-tuning/#findComment-3184334
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
