does this sound like the coil pack/spark issue i've read about?
its freezing outside tonight, and the boost climbed to 12psi. it was tuned at 10psi (unichip - 3inch zorst - 0.8mm platinum plugs - stock turbo - R33 S1)
there was a slight loss of power around 5000rpm, then all good after that.
the bit that got me concerned was my exhaust note changed from a roooaaaar, to a burbling wrx-like sound during the loss of power.
thats actually what alerted me to it. so i went again and noticed the loss of power.
Edited by Munkyb0y
plugs are 0.8mm platinum. AS ABOVE ^^^ open ur eyes blindman :D
they are only about 6000kms old
its never done this before. i can always feel the vct kicking in, but never had power loss or the weird exhaust sound.
its the exhaust sound that got me worried. i think it sounds like 1 cylinder wasnt firing maybe, and thats why i thought coil pack. also cold night, boost up to 12psi, where its never been before. sounds like the conditions where the coil pack might arc, or perhaps even the spark on the plug was getting blown out.
otherwise the car is driving normally.
basically what i need to know is:
for those who have had the cracked coil pack / weak spark issue. did your engine/exhaust sound like a burbling, wrx-type sound?
just trying to identify if its the same common issue.
if your coil packs are rooted, you wont be firing on 1 or more cylinders which will make it sound like a rex.
but also, as you mentioned it was cold outside, the intake air would have been denser than usual so you would've been running more power (obviously before it cut out) which explains the +2psi in boost as well as the car blowing out the spark at the plugs with a .8 gap.
if it was a 1 off thing then id blame it on the air temps. if its continuous then i'd be looking at replacing a coil pack, cas or gapping your spark plugs to .65.
i'd be doing the cheaper thing first.
lol, thats as good a reason as any.
i just took the car for a run. everything seems fine.
2nd gear, up hill (so plenty of load), all the way to 6500rpm, 10-11psi, smooth sailing.
so it looks like extremely cold/dense air was the issue. ie. boost was just too high for my coil/spark set up.
damn it !!!
it just happened again.
much less this time, but i could feel the hesitation at about 5k, and the same exhaust note, but it only lasted for a sec in 1st gear, and even less in 2nd gear.
is this related to the ambient air temps?
ie. it was worse on a really cold night. today is quite cold and the issue popped up again, but to a lesser degree. the other day it was moderately cold, and i had no prob at all.
i wonder if reducing my boost level would cure this prob. hmmm. need to get it on a dyno to do that though, as its a unichip integrated boost module.
Edited by Munkyb0y
rich and retard is a bit of a savage cut in power, very much like someone just kicked the brake pedal. if it is popping and missing then i'd say it is your coils.
but i'd get rid of the platinum plugs though. not a big fan of them.
check your cooler piping for leaks!
i must sound like an idiot since ive said it in numerous threads
but as secur1ty said, denser air, tiny bit more boost, might be a leak somewhere
thats what it was in my case
Guest tosboost2
OK MATE THIS EXACT THING HAS HAPPENED TO ME
and it used to piss me off all the time.
u would be driving along all good and then bang. (well not a bang) your driving a wrx. sounds cool and all. but no power. = coil packs dead.
now the easiest way to tell which one it is, is this.
go for a drive, wait for it to do it, and then pop your bonnet. take the connecting plug off each coilpack 1 at a time only.
if when u take a coilpack off it starts to die down even lower, its not that coilpack so put the plug back in and try again. until you find which one it is. because there will be one plug u take off that wont make the revs drop anymore and that is the busted coilpack.
i hope this help. i know its a little hard to read so if u want gimme a call on 0409890760 and i will explain to you over the phone.
cheers
scott
na i dont think it's the same problem as yours ^
mine does it for a second, at high rpm, but it goes away right then and there, before i even get a chance to shift.
it doesnt do it on idle, so removing each lead would not be any help
i spoke to my mechanic. he reckons its overboosting at prob 12+psi, and the ecu is backing it off. ie boost cut.
he puts it down to the cold air.
i'll do some more research, and see if this problem persists.
if it's the coil packs, it should start becoming more frequent yeah?
its never done this before, but now its happened twice, both times in freezing cold weather / higher boost than usual.
If it sounds like a Rex its missing. ie. missfiring.
But whats causing it is another matter, but problems with your spark plugs is fairly likley the cause.
Best take it back to the tuner and get his opinion them either fix it, or have him fix it.
hey man. i was in the same boat.. i still get it on a VERY cold night or morning(5 degree air) it starts to misfire around the 12-14psi mark.
i have R33 Series 2. stock turbo, full exh and fmic.
trust me its your coil packs, just like mine.. i would gap the plugs to say .7 or .65 as someone else mentioned.. or you could try copper ones pregrapped to .8mm.. as coppers are alot better then the plats. and save up for splitfire coils. really. thats the way to go.
im gettin mine for about 500 sooooon! :blink:
EDIT - r33's dont hav a boost cut.. its more like a AFM cut, the afm senses too much airflow and the ecu retards the timing and dumps more fuel in to save the engine, causing it to lose loads of power.. which in turn WILL/MAY blow out the spark, because the sparks too weak..and there u have your misfire..
For now, dont worry.. im in the same boat as you so i know how it feels!
i lost to a friggin B4 twin turbo cos of my misfire! damit.
EDIT # 2 - have u cleaned out ur coils? and checked for any arc residue???
Edited by Ultimategtr
it is known as rich and retard, and i'm sure munkyboy knows that. a lot people (even people who know it's proper name, unless they are majorly anal and have to call everything by its 100% correct name) will refer to it as boost cut. i do for 2 reasons. 1. it's easier to say. 2. it sounds a lot less gay.
but you aren't hitting it munky. you have a missfire problem caused by your coils.
r&r is a sudden, violent cut in power. anyone who has actually felt it will know that. there are too many people who have heard about it but never been in a car when it has done it so they will jump to conclusions. if you want to know what it feels like, go for a drive, floor it then with your left foot stab the brake pedal with a fair bit of force.
rich and retard sounds quite gay. like a wealthy kid who's been touched in the head :laughing-smiley-014:
but yeah, i was refering to the same thing.
mine doesnt feel like a violent jerking, so thanks for clearing that one up mad082. its hard to know if you havent felt it.
it sounded like coil/spark to me too. i was just hoping it wasnt. still better than something more serious.
so how do you indentify the coil pack thats playing up? i read about idling (at cold start?) in the dark and watching for arcs. i doubt its gonna do it at idle though. it idles smooth as always.
i might have to try cleaning the coil packs ...ala SECURITY
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
