LOL HOLY CRAP never heard anything so funny.. It never occurred to me and its been right under my nose for 27 years....
For anyone not following, 'Katse Fai Cota' means 'Sit down and eat chicken' in Greek.
yep that what it is
  • Replies 539
  • 2 months later...
small update
3l surge tank mounted under the car with a 360L/H pierburg pump and yes i know its not neat but i am sure the road wont mind. i also put a guard up to protect the pump from rear wheel shit hitting it.
Thursday. round 3 ill be there this time hoping that all is done and that it leaves with less lag, vct tuned, knock light turned back on, top end tuned, anti lag lunch turned back on,stalling over with.everything with the car is working and can't really see why it would not leave pulse racing with out a issue.looking forward to see paul tune the car the way it needs to be.
Lol. KFC thanks guys looking forward in seeing what happens today just sitting around the workshop now waiting my turn. The waiting thing always kills me it s like waiting for your wife while shes gives birth you just have to wait for it to happen when it happens
Well with out going to far in to my true thoughts this is the result of the tune this far 22 psi safe 11.7 to 11.5 AFR this set up would benefit with bigger cams 268/272 and 25 psi the set up would make just about anyone happy power delivery is crazy but fun out of second gear into 3rd leaves a brown mark in your undies 4th just makes it a little browner the acceleration is dam quick smooth hard and fast is the best way to tell you guys how it feels.its not bad for a gtx3576 there is room for improvment,
Edited by WARLORD
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
