Well i have heard many of the GTRs around adelaide have been in the past attempted to be stolen or stolen. The guy responsible was eventually put away, was caught red handed in GTR. How true this is, I don't know.
Where i used to park my car (last year), near the river at adelaide uni, the cops said at least 3 cars were taken from there every week. A GTR went missing from there too early last yr. After my number plates dissapeared from there, i decided not to park my car there anymore. The GTR recovered just had a small nick on the passenger side door where what appeared to be a screw driver or something had been instered to open the door. A computer of some sort was then hooked up to the car comp to override any immobs/alarms...The ignition barrel was stuffed.
I know I would be hysterical if this happened to me, despite insurance. I too despise car theives!
If you leave your GT-R in public view what do you expect?.. ofcourse some jealous scum back is going to come along one day and try to steal it.
the best insurance is to buy some $2000 car to run around in and leave in public :( lock your GT-R away when not neeed.
Even though I only have an RS-X (which I guess is same thing as a GT-R :) ) I would never leave the thing parked on the street for long.
the best insurance is to buy some $2000 car to run around in and leave in public :) lock your GT-R away when not neeed.
exactly what i do!
i dont have a gtr either, but ive put too much time and effort into my car than to have some f**kwit come and mess it up for me.
i aint got a GTR but if i caught anyone fooling around in my 33 id call the cops after done punishing them.
PS, if they know what their doing, chances are their on this forum, tracking you down in the GTRz0r as we speak =P
sounds too organised to me
do you think some person /persons are looking around these forums to find locations of gtr's ?
probably..
apparently the police lurk these forums as well so i wouldnt be surprised that ppl other then skyline enthusiasts go on here
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
