ahh well at least its in a nissan box not an ntk one. how much did they rape you for that?
there are aftermarket ones with the correct plugs that are direct plug in replacements.
:) its say NGK on the actual sensor...........got it for $168 something with GST, I asked here several times if those NTK or Falcon ones gona be ok for my GTS4 non-turbo, the answer was yes, when i calld NGK directly about this, they advised me it wont be 100% accurate so asked to get original one ;) was paranoid about getting NTK after that
well I think I should have gone for NTK one tho (like$70 i think),,, oooh well
Note- got a OEM oil filter from NIssan while I was there, well they are not really genuine I guess, its made in Thailand.............I love stuff from Japan :)
Hey all. Just wondering if there is a part number for the tacho modual in a R33gtst series 1 1995 dash cluster. I want to replace the tacho unit in my cluster. Trying to work out if cheaper to buy new modual part (which i doubt), or just buy a second hand cluster n mix n match parts?
Can you attually just buy the tacho gauge?
part No# 24825 21u01. tacho meter only
hey guys. Need help with part numbers.
I have checked everywhere in nissan fast i can think of and havent had any luck.
Its the metal thing covered in plastic that goes on the doors just below where the window starts (see picture....the thing circled in yellow)
For 1990 r32 gtst
vin HCR32064384
Need the part number for each side.
cheers guys
looks like 80820-04U00(RH) and 80821-04U00 (LH) "moulding assy front door outside"
there is another part 80834-04U00 (RH) and 80835-04U00 (LH) "weatherstrip-front door inside". I think that is between the trim and the window though.
Looks like 80820-04U00(RH) and 80821-04U00 (LH) "moulding assy front door outside"
Thats the one. Awesome work Duncan....cant believe i missed it :(
i know this will be hard to find i would imagine but im after the part no. for a brake master cylinder from a wgnc34 autech 260rs stagea series 1 if possible (i think s1, and s2 is the same)?
i have 34 brembos on the stagea and need a brake booster to suit but i found out 33gtr and 34gtr use different masters i cant see why if they are the same brakes? hopefully the autech one will be the correct one.
thanks
If you have the r34 brembos fitted, wouldnt you be able to use the r34 brake master cylinder? im havin a little difficulty with fast so i cant check right now but im workin on it now. somebody else out there with fast might be able to post up the number before i get around to it.
"it would be easier and cheaper to get after market 1s. google r34 eyelids or use the search button at the top here."
tried the search and majority of em are DIY or from carmate. AFAIK, aftermarket ones are approx 120ish after paiting whereas the nismo ones are around150++. Would rather get nismo in this case
Do you know where can we get nismo eyelids?
thanks mate, i am just wanting to make sure the brake lines all line up with the 34 master thats all, its rather expensive to get it wrong ($300 or so), i cant see why the 34 and 33 would be different?
When i can get fast working ill have a look for a part number. not promising that it will be there though. you could try calling a Nissan dealership and speaking with spare parts. They may be able to help you. If not, try searching yahoo japan auctions. there is several ways to buy from there including Slidewize performance I bought from Zac a few times. always delivered what ive bought. Theres other companies out there that can buy from the auctions on your behalf.
Yea expenses suck. There could be numerous master cylinders that will line up. Maybe best speaking with a mechanic. You might be able to find a cheaper alternative to the R34 1. Ill try to find the number when fast is working.
thanks
Sorry for the inconvenience but its been ages since ive used fast and i have actually never looked for stageas before. can you make it easier and supply me with a vin number? that saves me a lot of stuffing around
ive had a look but i haven't been able to find it. maybe someone else that has fast would be able to track it down.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
