Hi!
Need some advice....
At the moment I have speakers, sub & head unit running through my amp. I want to take my sub and amp out and so need to re-wire the speakers to run through the head unit.
Could anyone tell me what I should expect to pay for this? How long would it take?
I have spoken to Strathfield Car Radios and one store quoted $70 and another $120..
Appreciate your help!
Lj
https://www.sau.com.au/forums/topic/172892-re-wiring-to-head-unit-cost/
Depends on things like:
- what speakers are amped (front, back or both)
- if the standard speaker wiring, plugs and harnesses are still there - or if they need to be rewired
etc
Either quotes look okay, they're quoting around 1-2 hours it would seem, which would be fair enough.
if ur in melb i can give u a hand. its about a 2hour job at my place, matter or removing amp sub and taking wires fior speakers from boot or amp location back to the HU and re wiring it into the loom if the wires are to short to re-solder.
let me know
Hi!
Lj
If you are in Sydney i can Help. Im based in Parramatta. Pm me for more details.
if your in melbourne garys car radio mitcham, they do good shit, strathfield will rape your ass
quality of work is very good too because alls they do is sell/install car audio, no mobile phones no cleaning shit no car seat covers n so on.
let me know
Hey cheez! Thanks for offering to help me out!... but I live in sydney...
Cool! Thanks!
Thanks for the info! I've actually booked in to Strathfield for this weekend. They are charging $100, which I'm happy with.. In the end I had quotes ranging from $70 to $260..
Soon I will need to install the sub, amp, head unit and new speakers into another car.. (will not be doing this at Strathfield).. so any recommendations for sydeny based places would be helpful! I will also be searching the forum for ideas...
Thanks again
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
