As per title what brake pads for the street on an r33 with around 180rwkw......, only street driving....i was thinking of the sss pads by endless, but theyre quite pricy, unless theres some deals going on, i think its times to replace both front/rear pads as well.
Also, do i need to upgrade rotors when i get to my goal of 250rwkw?, and what fluid should i use when replacing the brakes?
thanks
https://www.sau.com.au/forums/topic/172927-brake-pads-for-the-street/
I used to love the ultimates but they chew your rotors something savage.
I now use Ferodo DS2500. Twice the price but lasts 6 times as long and doesn't rips the rotors.
You replace the rotors when your current ones wear out.
I have not had problems with pretty much any old Super Dot 4 fluid. The RBF600 certainly has the best specs although I've heard you need to change it more often because it is more hydroscopic than a Dot 4 or Super Dot 4 fluid. Basically the higher the numbers the higher the boiling point and therefore the better performing, but, as the numbers go up the fluids absorb more water so need to be changed more regularly.
All except 5 which doesn't absorb water at all so don't use it. 5.1 is fine though.
If you dont want your brake fluid to absorb mositure, wouldnt DOT5 be good, if you're saying it doesnt absorb water at all?
when brake fluid absorbs water its boiling point decreases... say from 400C to 350C. just pulling a number out my arse.
when you use DOT5 fluid it doesn't absorb water at all, so you end up with water in your calipers which a) rusts your pistons and b) boils at 100C, which is much lower than old brake fluid boils.
DOT5 is only for race cars where the fluid is bled VERY regularly. bad for street cars.
i would like to know as well..
i put dot 5.1 in for track day.. track day is over.. would i need to flush it out? what can a replacement fluid be for normal street use..
Nsta- Just use standard nissan pads.. they do the job fine for normal street driving..
If not, i like the project mu's
Have used them before and work very well..
I think ppl get too carried away with regard to Dot 5 and needing to be changed regularly, absorbing water etc etc. I have run nohting but and at times have let it go out to a year between even touching fluids, and there is normally no difference in pedal feel from old to new. Its more to do with the fresh pads i put in.
hydroscopic
just being nit picky here...
the correct term is hydrophilic.
hydroscope is used to look under water.
i never knew that... interesting
tend to agree with what roy said, i don't flush as regularly as i'd like - but more so with each pad change (which most of us would do a few times a year anyway).
For heavy street use i would recommend Ferodo TS2000 aka Formula.
I have looked around for a pad that performs somewhere between say Bendix Ultimates and Ferodo DS2500s and the Formulas seem like the best compromise.
Ultimates are about $100, Formulas are around $180 and DS2500s are now ~$290 (retail prices)
For light street use there is not much between those three pads.. For hard use the Formulas are a lot better. DS2500s are not worth the $$ unless you are using them for track work as well.
I would avoid using Ultimates again just for the fact that they badly destroy rotors. The Formulas are much better in that respect.
I've never used hydrophilic used to describe brake fluid, only hygroscopic. But both words are close enough :thumbsup:
Also, DOT5 is totally different to DOT5.1 - don't get them mixed up
hahaha thanks for that i have a chemical background.
diff between 5 and 5.1?
I did some googling, and thought i'd share my findings re brake fluids:
DOT 3, 4 or 5.1 indicates a glycol based fluid. DOT5.1 was designed with ABS systems in mind, where they need a lighter viscosity.
DOT5 indicates a silicone based fluid.
Glycol-based fluids are generally very hygroscopic, which means they readily absorb water (even from the atmosphere), which in turn lowers their boiling points, and lowers their overall effectiveness. It's recommended to only use brake fluid from an unopened container; once the bottle's been cracked, the remaining brake fluid quickly absorbs moisture from the
surrounding air. Even if you close the bottle immediately after use, there's usually a large charge of air trapped in the bottle enough to often ruin the rest of the fluid. Glycol fluids are also degraded by exposure to sunlight, and are well known and respected for their ability to almost instantly ruin painted surfaces
Silicone fluids are much less sensitive to environmental variables. They're essentially non-hygroscopic, eliminating the need for frequent fluid changes, careful handling, or wasting half-used bottles. This property also assures that the boiling point of the fluid remains fairly constant over relatively long periods of time. Military vehicles often use silicone-based fluids due to their ability to provide consistent performance over time, in inclement conditions, and without the need for frequent fluid changes.
Glycol-based fluids are generally non-compressible meaning that the force exerted by the master cylinder piston is transmitted directly to the caliper pistons. Glycol-based fluids give us the action and brake feel close to that of a straight mechanical linkage, but in a flexible hydraulic package. Silicone-based fluids, on the other hand, are somewhat compressible, giving a sponge-like feel at the lever, resulting in reduced braking force, delayed braking action, and vague feedback. In other words - they're not something you'd want to use if stopping quickly was your main concern.
In conclusion : Stay clear of DOT5 fluids!!!!
Edited by Trav33
I need new pads, and from all my forum reading i was set on the DS2500's, until i saw the price mentioned in siksII's post. Ouch! But you've made an awesome comment about Ferodo TS2000 (Formulas) being in the middle between Bendix Ulimates (rotor chompers) and DS2500's (too expensive). I will probably try a couple sets of these on the front+rear.
Thanks mate, i made a lot of calls and weighed up the options for many hours before making up my mind.. Im really indecisive.
The only other option in between the Formulas and the DS2500 is a new compound by Bendix called the SRT. They are about $250 and are meant to compete with pads like the DS2500.. I dont know anyone who has used them yet.
FYI the Ferodo Formulas have COF of 0.46 where DS2500s are 0.50, not much difference.. although the pads are made in different places so i think there is a bit more too it than just the COF when comparing the two pads.
I've never used those ds2500 pads, but was thinking about giving them a go. They're certainly not so cheap to just pick up a few different brands at the local store to give them a test.
Guys, while changing brake fluid may or may not improve pedal feel, the idea is to change is as preventitative maintenance. If you don't, the moisture will rust components. I try and do it every 12 months (i'd prefer 6, but i'm lazy). I buy 3 bottles of castrol ersponse super dot 4. Costs about $24. That's cheaper than an oil change. Takes about 1-2 hours.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
