Cubes..
"The holding a steady throttle, boost builds and then starts surging 'while' holding that same throttle opening"
That is the problem that I find difficult to live with. Motorways etc when doing 100km/h in 4th or 5th. This is definately a problem when holding a steady throttle and boost just coming on whilst maintaining same throttle input..
ANd when I say flicking between load cells...its more like 3 or 4 cells.
The AFM voltage I can see flicking between 2200 mv and 2700mv, you can feel a slight roughness but this oscillation is usually followed up by a large jerk and you can see the AFM voltage jump straight down the vertical when this occurs.
  • Replies 62
Posted Images
Its all good. I did skim read a touch and for one reason or another didn't see the 3-4load point drop but read it as flicked between load point 3-4. :)
Yes a larger turbine housing will sort the surge.
Improve the motors ability to breathe will also; You have cams and cam gears yet?
A turbine housing might set you back 50-100 + 300 for machining. Might be better off put towards a set of cams or reground rb26 cams? BUT its still not certian the surge will be sorted.
Reground rb26 cams are a shade over $200 for 2 sticks. You net around 8.5mm lift and ~252-254duration. So a nice mild increase that won't completely kill your low end.
Thanks Cubes. No I don't have cam gears or others. I am in negotiation with GCG so I may be able to sort something out with them because the turbo was sold as a standard Rb25 so should suit the car the way it is.
New cams are a big deal..take timing belt off, rocker cover etc. Not really up for that.
Your after the OP6 turbine housing.
I can't see by that pic if it is an OP6 or not.
The compressor backing plate actually looks the same as an early (series 1) RB20DET BB turbo I've seen.
Its definitely not the run of the mill Leopard/Cima Vg30DET turbo; it 'could' be a really really early turbo from one of those. Not sure.
The only VG30DET turbo I've seen is that from the Z31 which is journal bearing and then that of the later leopard/cima. The R34 GTT RB25DET Turbo also runs the same OP6 turbine housing that the VG30DET turbo does.
Can't be sure exactly what that turbo is without seeing more pics.
The OP6 is stamped on the outside of the turbine housing near the core.
So thats a journal bearing turbo?
Would be interesting to know what car that is off as they are an extremely extremely rare turbo if thats the case.
The Z31 VG30DET's as I said above run a VLT style turbo where as the Leopard/Cima VG30DET runs a the BB OP6 Turbo with 45v1/2/3/4 on the comp cover. It 'could' be the really early 1980-1986 Leopards; I'd assume they would have run around with the journal bearing turbo's. But whats interesting is why would they not have used the same old VLT/Z31 turbo.
http://cgi.ebay.com/ebaymotors/VG30DET-TWI...1QQcmdZViewItem
Thats a Vg30DET BB turbo with its OP6 Turbine housing.
Ha HAA ! I am sworn to secrecy on my Hi-Flow, suffice to say it'll do about 270rwkw, and has a watercooled plain-bearing core. It's not excessively laggy with the AVC-R tweaked-up correctly - certainly does the job for me, anyway!
Maybe You should investigate how changing the compressor housing slightly would affect surge? This seems to be at the heart of the problem, after all. Half a mil' here, a few thou' there.. . . might make all the difference.
Cubes, have all the ones you seen had OP6 in that location. This one has Y24B..
might not be right.
Hardman - sounds like you got a good turbo there. The secret recipe :) Yeah I think the compressor is where it's at but the exhaust housing may be the cheapest to change..
All of the larger turbine nissan turbo's I've seen have the OP6 on them.
You can't get any more pics? Get one of directly looking at the comp wheel also showing the compressor cover and one of the turbine housing in a similiar position. Then we can see both wheels and know or at least have a better idea of what it is.
Its definitely not a run of the mill VG30DET turbo; I suspect its something old. I suspect that due to the comp covers backing plate. Either that or its been highflowed.
If you have the turbo take some measurements of the turbine scroll at points that are easy to describe and I will compare them with the one I pulled off mine a little while back.
From memory the cross section width near the wastegate flap is ~5mm wider with the OP6 housing compared to that of the rb20/rb25 housings.
Anybody know if this looks like BB turbo? Do the non BB turbos still have exhaust housings that are useable?
thats a non ball bearing turbo, u can tell by the ribbing on the back of the front housing. To me it looks like a t3 off a VL Turbo!
Edited by mr_rbman
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
