its 1.8l dohc fuel injected its already got an exhaust but i want to put a cannon on ;)
it goes alright for a 4cyl alot more then my learners car :)
Noooooo..
first you start with a ricer car ( although not bad as getting a lancer CE etc).. then you want to rice it up more by putting a cannon on it..
It aint a turbo.. all its going to do is make it sound like a Deer farting...
and an intergra ba18 91 to a r34 GTR ---3k - 40k.. big step up there...
why o why do you have a sig of someone elses skyline in your sig.. join .SAU...then get a honda.. at least some of the L platers we got here got a non turbo model r33//r32 etc ( staying true to the cause.. you know who you are).
sigh..
Might got join the Toyota Supra club and tell em about my new Pintara that my gf got..
.......very well said, couldnt agree more....
you can get an r34GTR for 40k!!????
bottom range.. know i mate who got one green import for that price.. wasnt in bad nic..
ave ive seen is about another 15-20 on top of that.. but didnt want to make it sound as bad as an upgrade from 3k to 70k price difference :cheers:
dood calm down
first of all what kid doesnt want to put an exhaust on there first car
second of all ive got 3 years to save up because of the new p plater laws
its a first car i cant exactly control what i buy to get that car i earned $60 a week for two years and saved up
i looked at non turbo r33s because i couldnt find any 32's and they were $10 000
and im not looking at an r34 gt-r a r34 gt-4 with an rb26 a little bit different :bunny:
i like skylines but as a first car i payed for all my self through working i couldnt exactly afford one
i plan on joining the army next year and to save my money just like i have to get this car its cost me 4000 then another 1000 on insurance 1 years rego
plus the little things to fix up and to put some better speakers in ive got a bit over a grand to play with
the reason i got someone elses skyline in my sig is because i felt like it when i first signed up
do you have something against people puting pictures of r34 gt-r's in there sig when they dont have one
ill keep the rest to myself
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
