hi guys i have a r33 gts-t this is my problem, When i em in high rev's any wher between 5 to 7,000 my car starts to jerk and lose power. i know it could be hundreds of things but i want to know what you guys think it could be and if this has happend to any one else. THANKS IF YOU CAN HELP AND GIVE ME SOME FEED BACK
https://www.sau.com.au/forums/topic/173317-whats-going-on-with-my-r33/
Could be faulty AFM. Swap over if u have access, if not then resolderthe electrical contacts. Also check your coil packs.
Also if you have a pod filter, unsecured, get a CAI box or replace it withyour stock air box as this is what caused your problem with AFM.
99% chance it will be your ignition coils shorting out wich is a VERY common problem on the RB25DET engines
Quick test, take cover off the coils (black cover on cylinder head).. one way You could check them is to start engine and try to look for sparks whils reving and in the dark, But for mine the best way to diagnose if they are faulty (shorting out) is to give them a good spray with Inox (can be brought from bigw/ boating store etc) make sure you coat them well!.. than take the car for a good hard run and ill just about bet that you will no longer have the missing above 4500rpm, however this is not a permament fix.. it might last a few weeks max
The inox is insulating the parts of the coil that were beforehand leaking electricial current (shorting out) causing your engine to miss at the higher boost setting wich comes in at about 4500rpm from memory
If the coils are your probem there are ten thousand pages on here about how you can fix them or you can buy splitfire aftermarket ones wich is what some people do but your looking up to $1000.. i thing Sliding performance has a good deal on them atm for about $5/600
Dave
Edited by r33freely
You can check your coilpacks very easily. Remove the plastic cover over them. Then go for a 'spirited' drive at night when it's dark. Try to recreate the situation where the engine does its bad thing. Then pull over and pop the hood and stick your head in over the packs. I had bad packs, and when I did this, I could clearly see the spark arcing on 3 or 4 out of 6. Bought new packs, and 100% fixed.
Just easy to check this first since it's such a common thing in 'lines.
Just to let us know my car is stock all it has is a front mount and a pod filter
I had the same prob last week, it mostly occured when dropping down in gears on the freeway. it was my coil packs i took em out painted them with nail polish , it fixd them for now, i dare say coil packs are most prob next on my shopping list...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
