back before the GTR was born, in the late 60's there was a car called the GT-B, which basically won the Skyline's first race in japan. It was an N/A straight 6, with 4 doors. (Pete in SA has one of these, however Marvin, runs an RB20 from memory :Phttp://www.cardomain.com/ride/547037)
Autech in collaboration with Nissan, made the Autech R32 GTB commemoration edition. True to its ancestor, this car was a 4 door straight 6 N/A. They used the R32 GTS4 chassis as its base, and the RB26 engine, with different compression etc to account for the lack of turbos, however it retained the GTR's individual throttles. The body was massaged at Autech after leaving Nissan's assembly line, before it was painted in Autech poo brown/green :)
Anyways, that's todays history lesson over with kiddies.
It may be a shit spec to some of you guys (yes you guys who say "lolfag auto N/A"), but if you knew the history behind it, its a true collectible.
And technically you could import it, as the engine is actually a valid RB26DETT, and the chassis is a valid GTS4. Just depends on how lenient the compliancer is with the paperwork :down:
the dude who owns r31 house over in japan, put a rb26dett into a r31 then removed the turbo to make it an N/A cause she was scared of the power or somthing like that :)
Close. He built the car for his wife.
  • 2 months later...
  • 3 months later...
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
