you can't film them with out there permission. this was bought up AGES ago i can't remeber which thread otherwise i would link (and i'm not going throu 84 pages to find it :D) From memory it had to do with vange going through a yellow light and being pulled up by the cops
Edited by Whiplash
Always get the cop's id number and dont just sit back. If you feel you are being picked on dont be a nother soft cock, stand for your rights!!!!!!!!!!! I dont understand why ppl are getting defected for stupid things????? I understand if you have a bigger turbo or boost controler and all that but for stupid staff,Thats f**ked
Its fairly poor if we can't film the police.. What do they have to hide?
I'm assuming this is just an Aussy thing? Or has america since changed the laws that no one can film them after the big black bashing incident that caused massive riots?!? This exact reason is why we should be allowed to have to power to film police should we feel the need they are abusing their power.
I feel your pain... i was defected down near morphett vale, exhaust too loud and 30mm too low straight to regency with my 32 GTR. H didnt really seem to care that i have just replaced all my suspension and bushes along with my subframe bushes, new tyres and the list goes on to actually improve the safety of the car. He goes on to say these things are fast and could outrun a cop car, i thought to my self well why the hell did i stop? ahah
Does anyone know if GTR and GTST sroings are different? I thought gtst would be lighter grade as car is lighter...
as youve mentioned, youll definitely need to return it to stock ride height.
get rid of your boost gauge temporarilty, and make sure you hide any of the wiring that powers it.
As for your exhaust, they dont actually defect aftermarket systems (providing you have a cat convertor to comply with emissions); they actually defect the noise level: from memory, i think the max sound level youre aloud to have for a 6cylinder is 90DB. (mine measured 93, and they still fkn picked me for it... wankers.)
if you have a turbo timer, you will need to lose that as well.
They will also check/do: a brake test, check that child anchorage points are accessible through your parcel shelf for a baby seat, check your tyres arent too worn, test your seat belts, test your indicators lights and brake lights, test your horn, they will basically examine underneath your car for rust, seized up bushes etc, and of course > they will peer under your bonnet for stuff that isnt ment to be there like open to atmo BOVs. They cant say f**k all about the stock one. You should be able to pass with a pod filter, and a sturt brace as well.
93 dB is twice as loud as 90dB. Its a logrithmic scale and every 3 dB is double the volume. Its its twice as loud as the legal limit, not only just over.
i thought that logorithmic scale was to the power of 10, so it required unit of 10 times the magnitude to double the volume.... then again its been soooo long since i've done any maths, its probably all wrong
edit: actually its the other way around, you increas the volume from 1 to 10, it doesnt increase it 10x it increases it 100x... however i think its diminishing as you increase the volume, from 90 to 100 isnt a 100x increase... anyhows, rambling, and was initially wrong, still dont think its twice as loud... =P
Edited by Fishpaste~
for a R33 GTR and GTSt use the same front's but the rears are different
sorry to hear of your unfortunate date with police
you would be able to ring a traffic solicitor to find out about filming the police and if when i speak to mine next i remember i will ask him
but you will have to remember the act that allows you this right otherwise they would tell you, you cant
he cant touch me if i choose the record him, if he does ill charge the cop with sexual assault.
dont worry mate i think you be safe from getting touched anywhere sexual lol
Edited by sinistagtst
its sad... my car isnt even as loud as a lot of others out there (until the revs climb high of course). You do need to remember with this sound test though, they make you rev to about 3500rpm then measure the sound.
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
