To help kick off the Drift Australia Round 3 Weekend, NissanSilvia.Com and Ignition DVD are organising another one of their HOTSPOTS.
Basically a large scale meet and cruise, they will be filming for the upcoming issue of Ignition.
With any luck, some of Sydney’s nicest showcars will be out, possibly with an appearance of the Alpine Mini Cooper S Speedster.
I'll be there. I think this will be a pretty big event and as it's an official kind of thing there shouldn't be any problems with hoons or cops.
https://www.sau.com.au/forums/topic/173804-big-meet-and-cruise/
  • Replies 44
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
