I don't know much about clutches, but i'll reply anyway. You say you smell burning whenever you go hard? Well it could be your brakes, if you're braking heavily or alot when you're going hard. If your clutch is not working good, as far as i know it will slip alot, and that's how you can tell if you need a new one. Exidy clutches are supposed to be a good brand also.
That's all i know :D
Ryan
https://www.sau.com.au/forums/topic/1740-clutch-done/#findComment-33089
The clutch will slip in higher gears (lower too - but not as obviously i think) .. like you'll put your foot down and the car will rev and you wont gain speed... you'll notice it.
If you continue to let it slip for a long time, you can damage the flywheel, but thats about it (i think) eventually the car will be undrivable..
mine went not long ago and i have a 5 puck brass button clutch in there now - absolutly fantastic!
Christian
https://www.sau.com.au/forums/topic/1740-clutch-done/#findComment-33112
Christian
I think theres a chance that you flywheel can shatter too. I drove
my to the point where it just wouldn't move anymore, not that
I'd recommended such an action. :) Smelling your clutch through
the air vents is a definate sign.
https://www.sau.com.au/forums/topic/1740-clutch-done/#findComment-39517
full face organic just means that it is like the stock clutch plate, i.e full face and made from organic material. You should specify a higher pressure plate like 2400lbs or such and maybe even steel backing on the clutch plate. As for driving the car with a slipping clutch, I did it and was shocked when we pulled it out. The actual clutch/friction plate was fine and had heaps of meat left but the pressure plate and flywheel where toast. It is not a good idea to ride a button clutch. :(:P
https://www.sau.com.au/forums/topic/1740-clutch-done/#findComment-39749
Alot of people have said it's a good clutch. Mine's basically a
custom one. Everytihng is Exeidy Dakien Full Faced Organic
except for the compound used. Pressure plates a bit heavier
too. It's supposed to be slightly stronger. I think it's a bit too
strong now cause I think the next thing to go on my car is my diff,
bit harsh on the takeoff. So I think it would be perfect for the 33.
Just remmeber to bed it in properly or you will regret it later.
https://www.sau.com.au/forums/topic/1740-clutch-done/#findComment-39881
Here is my clutch story -
Had a std clutch in R33 which I killed in about 3000 kays.
Then put in a single plate nismo one which lasted about the same.
Then I had to replace the gearbox & fitted a twin plate OS Giken.
I had trouble at the drags with this one slipping at the top end, so
we fitted a triple plate OS Giken clutch.
Then I blew up the gearbox (a Trust 6 speed!) doing burnouts in 2nd gear.The clutch still looked okay at this stage but one of the plates was starting to go blue more than the others.
When I blew up the engine at the 4.6.&Rotary Nationals in Adelaide in Feb, we replaced the engine with a OS Giken 3 litre.
The crank in this engine has 8 bolt holes for the flywheel(not 6)
so I had to change the clutch again!! Now I have a Quad plate,
Chrome moly, 8 bolt OS Giken clutch. I'm sure this one will last.
Moral of the story - Get the right clutch for your application first up
PS. At Drag Combat in May I completely smashed the std rear driveshafts in 2 places and have since replaced them with HKS
shafts. When the gearbox came out for a checkover the clutches
in the transfer case were fried 'cause I backed off the startline using Fwd only.
I now have a fresh transfer case, a fresh gearbox, HKS shafts front & rear, & a hydraulic torque split controller so all 4 tyres
better look out now!
https://www.sau.com.au/forums/topic/1740-clutch-done/#findComment-40742
Originally posted by Zahos
Hey ex-static
If u dont mind me asking, where are you getting the clutch done, and approx how much $$ is it going to set you back?
Zahos
I got it done at Ice Performance in Cheltenham, its an excellent clutch, very light, and very grippy! I highly recomend it.
-ex
https://www.sau.com.au/forums/topic/1740-clutch-done/#findComment-41124
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
