  • Replies 51
Posted Images
  • 4 weeks later...
still some to finish off
needs the following :
cut out to clear the fuse box mount
billet alloy filler cap
holes for the washer pumps
-10 fittings for the breather hoses
drain plug for catch can side
finish fillet welding the 2 bits together (amps needed keep throwing the breaker lol)
figure out what kind of outlet is required - either for filter or plumb back
looks good chris. making one up myself at the moment, how thick was the aluminium you used and what type of aluminium was it? Does it make much of a difference when it comes to welding if your using a soft or hard ally?
This is 2.5mm alloy using 1.6mm filler rods
i am not sure on the grade of filler at this point or the alloy grade for the sheets- i just get off cuts and run some test welds to work out the best Amps for that alloy im using.
its just a shame the TIG im using does have a foot controller.
yeah fair enough - first posts one was without filler
going to make a couple more and get them welded up without filler
the one above i'll get the fittings and filler welded on - this one would be fine for powdercoat as that neatens up the welds heaps.
you're doing good stuff man.
I might be interested in 1 of the split washer bottle/catch cans actually...probably just in the raw metal finish...any chance of PM'ing me with a rough price?
let me finish this one off and then i'll let you know
would be different if using another dash fitting for legal plumb back versus getting a filter for it
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
