Hey guys
Recently took the car for a spin through a mountain range .. within speed limit but heavy braking with alot of 25km/h corners by the return to sydney the brakes felt like I had 0 pads left.. But they are 70-80% still
Straight to the mechanic .. Lucky I was booked in for the day and we went into the night with a few mods..
Anyway ..
Bleed out fluid - Refilled
Machined discs Rears only fronts are fine
However underbraking now feels like its a old kingswood with stock booster and a wicked braking system .. I press down on the brakes slightly and get awesome braking if I push harder to slow its very hard to press and without much result.
Now im assuming this is because the mechanic filled the fluid up past the full mark right to the top with no air in the system but would this cause such strange braking?
I also feel the high heat and stock pads caused maybe a glazing over of the pad and its not working efficently any more? Could this happen?
So in short..
1* Remove the overfilled fluid?
2* Sand the brakes down?
Cheers
https://www.sau.com.au/forums/topic/174102-braking-system-stiff/
Would suggest:
1: Re-write post so that is atleast sounds coherent. :(
2. Invest in a brake master cylinder stopper from someone like Cusco to stop the firewall flexing.
3. Don't worry about the level of fluid - as the pads wear it will lessen.
4. Depending on how much braking you are doing it may just be fade, ie pad gets hot, pad loses friction coefficient.
but it worked fine before and now it works shit house basically.. but before i.e after mountains I had the foot close to the floor with little/no brake?
And yeah I tend to blab on sorry, grammar isnt my strong point either.
Do you think the pads will wear "back to normal" or will they be forever shocking? i.e until I get new pads
Edited by DECIM8
Would suggest:
2. Invest in a brake master cylinder stopper to stop the firewall flexing.
Ok.. excuse the noob question.. but how does this work? :(
How does the product work and how does it stop flex in the the firewall? I take it it stop flex as in twisting under extreme conditions?
Mechanical explination?
thanks mate =]
Well if your foot was close to the floor you probably boiled your fluid in which case replacing it should make the problem go away.
With regard to the pads - well some types come back after they get too hot, but others are stuffed for ever more. It depends on what they are made of.
If you want an opinion I would spend the $200 or whatever on some new pads. They are after all some of the most important parts on your car.
thanks mate =]
It stops the master cylinder from moving forward by placing a mechanical stop in front of it (tied to the shock tower)
See the photo.
If you want to get an idea of what is going on lift the bonnet & watch the master cylinder whilst a mate presses on the brakes...
thanks alot I deff think I boiled the fluid but i drove home on the freeway for a good hour in 10 degree temps at 100+km without touching the brakes .. it was then I realised they had been rooted...
So ill give it a go for another week or so .. they stop but just harder .. might buy some new pads .. they are only nissan stockers anyway
Standard pads are hopeless for track use - try Ferodo DS2500s. Also use high temp brake fluid, like Motul 600.
Heh, if you're anything like me you didnt notice they were rooted on the track because you were pumped with adrenaline and using huge force on the pedal without realising!
Seals are ok, Got them checked cheers tho..
Really think its just the pads which are rooted.. Will investigate the Ferodo DS2500s or whatever its called .. anyone suggest a cheap place to pick them up?
Edited by DECIM8
Well drove it for about 3 days now and seems its just glazed over the pad, seems theyve over heated and put a slippery surface onto the top of the pad.. I assume so anyway because they are back to normal maybe a little better..
Will be buying new pads still just for safety
It is burned/glazed pads. If the fluid boils it will be a momentary thing and your brake pedal will go to the floor while it's boiling. It will also do this if the fluid has absorbed water and the water boils. You can take the pads out and sand the glazing off, basically when they get too hot they can form a glassy like layer on the surface (at least the ones I've seen have done so, racing compounds might be different) and then it doesn't bite into the pad properly. But if you sand it back and re-bed the pads they are usually ok.
I would still replace the pads as you are going to do anyway, because once they're over heated that much I wonder if the pad material will become brittle and and start to break off. Also you may have put hot spots on your disc but you will probably not notice that for awhile. The hot spots will start accumulating more and more pad material and then you'll get a shudder under brakes. It is what most people think are warped brake rotors but it's just excess pad material accumulating in the hot spot.
Changing fluid to a better grade can also help, I'm not sure what the consequences of boiled fluid are but I imagine it's not good. It will probably make the brake pedal more spongy after it cools down. I've only experienced boiled fluid in a mate's car but it had absorbed a lot of water so not really the fluid boiling. So after we nearly died after losing all brake pressure, I detoured slowly to buy brake fluid and then to my place and I changed his brake fluid. He owes me big time!
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
