Hay guys,
Im interested in getting a set of cams.. But i dont like putting things in my car if I dont fully understand how and what they will do. So I have a few questions (mechanical explinationes prefered)
What are the complications with getting exhaust and inlet aftermarket cams in a CVT 25DE?
What size's/lift/duration are best for street driving? Anything to enhance Mid AND high range?
How much power will gain with a good tune?
What prices am I looking at for a good set of cams?
Is it worth going overkill and getting massive cams? What are the differences in cams? E.i How and what happens if you increase left/duration?
How do I tell the left/duration?
Will I have to get cam gears?
At what point will I need to go larger injectors?
Thanks in advance guys! :(
https://www.sau.com.au/forums/topic/174108-cams/
Will have a go at some answers...
Um, like....?
With regard to this motor, not sure.
Depends on the cam & any other components fitted.
About $1k for two. Sometimes more.
No. This will simply remove low & mid range torque & you wont be able to pick up any top end hp.
Lift (not left) is simply the amount by which the cam lifts the inlet and or exhaust valve away from the head. Duration is the length of time (in degrees) that the cam does this for. More duration valve is open longer, more lift valve is open further.
It will be stated by the manufacturer.
Not necessarily.
When you run out of injector flow. Broadly every cc/min in a 6 cylinder equates to a rwhp.
Edited by djr81
https://www.sau.com.au/forums/topic/174108-cams/#findComment-3196502
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
